Dont understand this momentum problem
  • Thread starter Thread starter physicskid72
    Momentum
The problem involves two air track gliders with different masses and initial velocities colliding elastically. Participants are tasked with determining the final velocities of each glider after the collision using the principles of conservation of momentum and kinetic energy.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss the use of conservation of momentum and conservation of kinetic energy equations to solve for the final velocities. There is uncertainty about how to manipulate these equations to isolate the variables needed for a solution.
Several participants have reiterated the need for two equations to solve for the two unknown velocities. There is ongoing exploration of how to combine or rearrange the equations, with some participants suggesting substituting one variable into the other to simplify the problem.
Participants express confusion regarding the application of the equations and the process of solving for individual velocities, indicating a need for further clarification on the steps involved.
physicskid72
Two air track gliders of a mass 300 g and 200 g are moving towards each other in opposite directions with speeds of 50 cm/s and 100cm/s respectively. Take the direction of the more massive glider as positive.
A.) determine the velocity of each glider after the collision if the collision is elastic.
m1v1i +m2v2i = m1v1f + m2v2f
quoted by "collinsmark" - "You have enough information to solve it (given that this is a 1 dimensional problem -- things can get more complicated if the objects can freely move in more than 1 dimension)."
"You have the conservation of momentum equation that you listed above. But since you are assuming it is a perfectly elastic collision, you can also use conservation of kinetic energy (conservation of kinetic energy only applies if the collision is perfectly elastic). So you have 2 equations and 2 unknowns, which is solvable."
I know collinsmark was right in what he is saying but i don't undrstand what formuals to use to get the separate velocites.
Like this?
3(0.50) + 0.2(-1.00) = 0.3v1f
3(0.50) + 0.2(-1.00) = 0.2v2f
then solve for the separate velocites in each case?
or just m1v1i = m1v1f
so the velocity doesn't change only in direction.
any help is greatly appreciated.
This is conservation of momentum, so this is one equation.
Next you have an elastic collision, meaning initial kinetic energy = final kinetic energy, this will give you another equation. Now you can solve these two equations for the velocities.
You had the first equation you need ,correct, in the previous post; now you're getting it messed up. You didn't take collinsmark's advice about the second equation you need to solve (a bit tediously) for the 2 unknowns . You should go back to that original post post and seek additional help there.
i know the two equations are
and
1/2(m1)(v1i)^2 + 1/2(m2)(v2i)^2 = 1/2(m1)(v1f)^2 + 1/2(m2)(v2f)^2
or
KEi = KEf
I'm just not sure how to solve for the individual velocities.
and
Right, it's easier to plug in the numbers than to deal with all of the symbols, but when you plug in the numbers, try gathering the like terms on one side of each equation.
it is still vague, do i combine the two equations? i mean if you simply rearrange you end up with two variables to solve for so you must have to use a combined formula right?
take the first equation, make one variable the subject and substitute it into the other equation.
  • · Replies 16 ·
  • · Replies 22 ·
  • · Replies 16 ·
