Understanding Doppler Shift: Impact on Sound Waves and Airplane Movement
The discussion revolves around the Doppler effect as it applies to sound waves emitted by an airplane. When the airplane moves toward a stationary reflector, the frequency of the reflected sound increases due to the compression of wavefronts, resulting in a higher pitch. Conversely, when the airplane moves away from the reflector, the frequency decreases, leading to a lower pitch. The participants clarify the roles of the source and observer, emphasizing that the source emits sound waves and the moving plane reflects them. The conversation concludes with a consensus on how the Doppler effect influences the perceived frequency based on the relative motion of the source and the reflector.
jsmith613
Imagine this scenario:
An aeroplane emits a sound wave. The sound wave propagates in all directions.
a) If the plane is flying forward, it emits a sound towards a reflector in front of it. When the sound is reflected, its frequency is reduced, presuming the plane is traveling towards the reflector
b)If the plane is flying in the other direction, it emits a sound towards a reflectorbehind it. When the sound is reflected, its frequency is increased, presuming the plane is traveling away from the reflector
Why are a) and b) as they are
Seems like you have those situations reversed. When the plane is flying toward a stationary reflector, the frequency of the reflected sound will be higher that the source frequency.
Yes sorry, I confused it.
The question still remains. why does it happen?
Is "doppler effect" a good answer? If not, then do you know the doppler shift equation?
That's just the basic Doppler effect. Think of succeeding wavefronts as getting bunched closer together when the source moves towards the observer (resulting in higher observed frequency). It's the reverse when the source moves away from the observer.
See: http://hyperphysics.phy-astr.gsu.edu/hbase/sound/dopp.html"
Brin - I do know what doppler effect is!
Doc Al - just to clarify then,
the transmitted wave will have a constant wavelength / speed / amplitude.
The wave will be reflected when the wave hits the plane. If the plane gets closer then the waves are reflected quicker so the reflected wavelength is smaller
I thought the plane was the source? There's a moving plane emitting sound at some frequency approaching a stationary (with respect to the air) reflecting surface.
Yes. If the plane approaches the reflecting surface, the reflected sound will have a higher frequency and shorter wavelength (compared to the source).
The doppler effect is that thing where the cop car is driving towards you with its sirens blaring and it sounds high pitched, then as it drives away it is lower pitched.
Or, when there is a man being swung around in a circle, and you are standing to the side watching. As you listen to him screaming for help, you'll notice that the pitch of the voice changes as he gets nearer than farther.
If a plane is flying towards you, it'll have a higher pitched engine noise than when it is flying away from you. You definitely hear the frequency change as it flies by you. All of these examples are to illustrate that for the frequency you hear, there is a connection between the frequency of a noise, and the velocity of the object emitting the noise.
No. The source emits the sound and it reflects off the plane. Let's get that bit clear.
That is why I was confused.
Even with this siutation applying, do the same principles work
OK, but that's different from the scenario you described in your first post. Please describe the situation you want to discuss: Where's the source? Where's the observer?
Sure, the Doppler effect still applies. Once you define the situation, we can apply it.
Sorry about the confusion:
Here is the situation:
A stationary SOURCE emits sound waves.
a MOVING plane reflects these waves
the SOURCE also detects the reflected waves.
If the plane is moving nearer then the returing wavelength is shorter
If the plane is moving further away then the returing wavelength is longer
So what is going on is that when the source emits the wavelength and the plane moves nearer the reflected sound waves sqash closer together because the plane is constanlty reflecting the waves as it gets nearer
Correct?
OK.
Yes. If the plane moves towards the source, then the observed wavelength is shorter.
Sounds good to me.
Doc Al said:
OK.
Sounds good to me.
Thanks for your help!
