Juggler123
- 83
I need to find the area between the parabolas x=y^2 and x=2y-y^2, I know I need to use a double integral but am having difficulty finding the limits. Can anyone help please?
Juggler123 said:I need to find the area between the parabolas x=y^2 and x=2y-y^2, I know I need to use a double integral …
The purpose of finding the area between parabolas is to calculate the total area enclosed by two intersecting parabolas. This can be useful in various mathematical and scientific applications, such as determining the volume of a shape or finding the work done by a force in physics.
To set up a double integral for finding the area between parabolas, you will need to first draw a graph of the two parabolas and determine the limits of integration. Then, you will need to choose a suitable order of integration and set up the integral using the appropriate formula, such as the formula for finding the area between two curves.
A single integral is used to find the area under a single curve, while a double integral is used to find the volume or area between two intersecting curves. In other words, a single integral is in one dimension, while a double integral is in two dimensions.
Yes, a double integral can be used to find the area between any two curves, not just parabolas. The method for setting up the integral may vary depending on the shape of the curves, but the concept remains the same.
Yes, there are many real-world applications for this concept. For example, in engineering and architecture, finding the area between curves can be used to determine the volume of a 3D object or the surface area of a structure. In physics, it can be used to calculate the work done by a force, and in economics, it can be used to determine the area under a demand curve to find the total revenue.
