Drag force on a sphere moving through a fluid
The drag force experienced by a sphere moving through a fluid is influenced by turbulence, with the force expressed as F = kp(R^2)(v^2), where k is a constant, p is the fluid density, R is the sphere's radius, and v is its speed. This relationship indicates that the drag force is proportional to the square of the velocity and the square of the radius of the sphere. For accurate calculations in real-world scenarios, the complexity often necessitates the use of simulations rather than straightforward analytical methods. Understanding drag force is crucial for various applications in fluid dynamics. The discussion highlights the challenges of calculating drag forces in practical situations.
Tulatalu
A body moves through a fluid, a retarding force due to turbulence may be experienced. In case of a sphere of radius R moving with speed v through a stationary fluid of density p which it at rest, this force is given by
F = kp (R^2) (v^2)
k
is a constant.
Why F is proportional to kp (R^2) (v^2) ?
Google for "drag force calculation" and you'll find many good derivations. In practice, with real objects moving through real fluids, the calculations are hairy enough that we often resort to simulations.
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
