Why is the Drift Current of a PN Junction Independent of Bias?
The drift current density in a PN junction is defined by the equation J = qnv, where q is the charge, n is the carrier density, and v is the drift velocity. While the drift current is influenced by the mobility of charge carriers and the electric field, it remains independent of bias because the density of minority carriers does not change with applied voltage. In contrast, diffusion current is affected by bias due to the exponential variation of majority carriers. The discussion highlights a key point that while minority carriers accelerate in an electric field, their overall density remains constant, leading to the conclusion that drift current does not depend on bias. This distinction between drift and diffusion mechanisms is crucial for understanding semiconductor behavior.
get-physical
The magnitude of a drift current density is given by J = qnv, where q is the carrier charge, n is the carrier density per unit volume, and v is the carrier drift velocity. q is a physical constant and n is independent of bias. But when an external electric field is applied, the minority charge carriers must surely accelerate and change their drift velocity. How is the drift current of a pn junction not a function of bias?
The drift current of a pn junction is dependent upon the bias placed across the junction. The drift velocity v is dependant upon the mobility of the holes and electrons in the junction as well as the electric field placed across the junction.
The equation for drift current that I learned was Jdrift=sigma*electric field where sigma is the (q*n*mobility)
It is as far as I know a function of the electric field as well maybe re check the equation
There are two mechanisms of conduction in a semiconductor: diffusion and drift. Diffusion current, on one hand, is clearly affected by changes in bias because the number of majority carriers that are able to diffuse across the junction varies exponentially according to the Maxwell-Boltzmann distribution. On the other hand, minority carriers do not face a potential barrier so their number is unaffected by changes in bias and that is the crux of the explanation as to why, according to every reputable source I've come across, the drift current of a PN junction is independent of bias. But the fact that minority carriers accelerate and change their drift velocity in the presence of an applied electric field is never accounted for. Why?
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
