Drift Speed of Electrons in Conductor with Applied Field
Drift speed in conductors refers to the net speed of electrons moving against an applied electric field, initially moving randomly. The acceleration of electrons is influenced by the electric field and their mass, but this acceleration is not constant due to collisions. In a steady-state scenario with a DC field, electrons eventually flow at a constant drift velocity after an initial transient period. For AC fields, the drift velocity varies sinusoidally, reflecting the changing current. The drift speed is considered an average, as individual electrons experience different speeds and interactions within the conductor.
person_random_normal
for an electron, randomly moving inside a conductor , having applied an external electric field we have those electrons moving with a net speed called drift speed , against the direction of field.
so initially as electrons are moving randomly we consider their initial velocity o
and after time t =at
where a = acc. of electrons = e(field)/mass of electron
t = mean time between consecutive collisions of electrons
courtesy PHYSICS by halliday resnick krane vol 2
but i don't understand why don't we average the initial and final speed of electrons ie
drift speed = (0 + at)/2
The acceleration of an electron in a real conductor is not constant. I think when subjected to an electric field, the speed of the electrons increases monotonically up to its "steady-state" drift velocity. If the applied field is not changing (DC), then after an initial transient time, the electrons are flowing at the drift velocity. If the applied field is a sinusoidal function (AC), then the current (and thus drift velocity) will also vary sinusoidally. An accelerating charge (i.e. a varying current) establishes an electromagnetic wave.
I think drift speed is already an average since every electron will be moving at different speeds and constantly interacting with the material and the applied field.
For the acceleration happened just a moment (average), the drift velocity is the average speed electrons have in the conductor after the generation of the electric field.
The electron in a (normal) conductor is under the influence of the electromagnetic force and to a friction force. The notion of a friction force is already a coarse grained description of the full complicated dynamics of the many-body (quantum!) system. On the level of linear-response theory you come astonishingly far with very simple classical pictures introducing some phenomenological transport coefficients (like electric conductivity) and response functions. On a microscopic level, you have to calculate appropriate correlation functions in statistical many-body QFT. See Landau-Lifshitz vol. X for a very good introduction into both classical and quantum transport phenomena.
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
