Drift Velocity ambiguity in relation
The discussion centers on the ambiguity of drift velocity equations, specifically v=(eE/m)t and v=(eE/2m)t. Participants suggest that these equations may apply to different scenarios, with the first representing uniform acceleration in an electric field from rest, while the second could describe a situation with equal initial and final velocities in opposite directions. This interpretation indicates that the velocity difference in the second case matches the first setup, leading to similar outcomes. The conversation highlights the need for clarity on the contexts in which each equation is derived. Understanding these distinctions is crucial for accurate application in physics.
justwild
How is it possible that the two relations i.e.,
v=(eE/m)t
and
v=(eE/2m)t
both holds good?
where e is the elementary charge, m is the mass of the elementary particle, E is the electric field, v is the drift velocity and t is the relaxation time.
Where do you get these relations?
Maybe they refer to different situations. The first one looks like a uniform acceleration in an electric field, with 0 initial velocity.
The second one might come from a situation where the initial and final velocity have the same magnitude (butopposite direction). Note that the velocity difference is then twice this value, and therefore identical to the first setup.
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
