Droplet impact angles, errors in.
The discussion focuses on calculating the impact angle of water droplets on surfaces using the arcsin of their width and length. It highlights that as the angle approaches 90 degrees, small measurement errors in width and length significantly affect the angle calculation. The original poster seeks mathematical guidance on exploring this relationship, including confidence intervals for impact angles. A follow-up comment expresses frustration over the lack of responses and requests for more information. The conversation emphasizes the challenges in accurately measuring droplet impact angles.
TeraExa
Hi
Arcsin width/length of a water droplet on any surface will give you the angle between the droplet trajectory before falling (assume straight line rather than parabola) and the surface upon which it fell.
As this angle approaches 90degrees (water drop falling vertically on a horizontal surface) measuring these two variables [width, length] will be more difficult as even a small error will result in a large difference in the angle calculation.
I would like to investigate mathematically this relationship, such as working on confidence intervals for angles of impact as functions of angle of impact itself etc. but I would appreciate some guidance as to how to go about it.
Thank you
Alex
replies
why did nobody reply? do i need to supply more information?
thanks!
:confused: :confused:
I was reading documentation about the soundness and completeness of logic formal systems. Consider the following $$\vdash_S \phi$$ where ##S## is the proof-system making part the formal system and ##\phi## is a wff (well formed formula) of the formal language. Note the blank on left of the turnstile symbol ##\vdash_S##, as far as I can tell it actually represents the empty set. So what does it mean ? I guess it actually means ##\phi## is a theorem of the formal system, i.e. there is a...
