Mk
- 2,039
- 4
Is it physically possible to drive through a rainbow? Why or why not?
A rainbow does not actually exist at a location in the sky, but is an optical phenomenon whose apparent position depends on the observer's location. All raindrops refract and reflect the sunlight in the same way, but only the light from some raindrops reaches the observer's eye. These raindrops are perceived to constitute the rainbow by that observer. Its position is always in the opposite direction of the sun with respect to the observer, and the interior is slightly brighter than the exterior. The bow is centred on the shadow of the observer's head, or more exactly at the antisolar point (which is below the horizon during the daytime), appearing at an angle of approximately 40°–42° to the line between the observer's head and its shadow (this means that if the sun is higher than 42° the rainbow is below the horizon and cannot be seen unless the observer is at the top of a mountain or a similar vantage point).
When the rain is uniform, the rainbow that you see is a cone with your eye in the apex. So you will never have the impression of approaching the rainbow, because it always extends from your eye to very far away.Neveos said:As we got closer, we realized that we might actually approach, what appeared to be, the end of the rainbow.
When you get into light rain that sprays your windows with tiny water drops, with the sun low, you will see a lot of nice color effects. (However, this can be annoying when you are trying to land a glider, which don't have wipers.)Neveos said:The interior of the car became very bright, and it did, in fact, change colors all around us. I vividly remember my arm lighting up as though it were being shined upon by a sequence of colored lights.
It was a bit more distinct than this to my memory, however I do not discount the possibility of wishful thinking playing a role in what I saw. I'm not willing to discard what I vividly saw, which was the colorization of the interior. There are actually a lot of videos surfacing on youtube of people getting close to the foot of rainbows, so it seems to have happened enough times to accrue a number of eyewitness accounts. A lot of other people are saying they witnessed a change in colors as well. However, from the videos, it does appear that it is less manifestation than I thought, so I am inclined to believe that I am wrong. However, being able to "pass" and "approach" a rainbow, to the degree that one is capable of is quite different than one would expect from messing with standard rainbows made in a mist.When you get into light rain that sprays your windows with tiny water drops, with the sun low, you will see a lot of nice color effects. (However, this can be annoying when you are trying to land a glider, which don't have wipers.)
Link some that are similar to what you saw.Neveos said:There are actually a lot of videos surfacing on youtube
That is no problem as I decribed above. In fact, once you drive into the rain, the foot of the rainbow (intersection of the cone and the ground) starts right outside of your car.Neveos said:of people getting close to the foot of rainbows,
The water drops that send light of a certain color to your eye have a well defined position. They form a cone surface with your eye in the apex, and an axis patallel to the sun rays.sophiecentaur said:A rainbow is a virtual image that is not, actually, anywhere.
Not really. It will appear where the water drops are. It can extend from your position to a few kilometers away.sophiecentaur said:Mostly (when in the sky) it will appear to be at infinity.
It doesn't just appear to be in front of a distant hill. It is in front of it, if the rainy area is closer than the hill.sophiecentaur said:But it can often appear in front of a distant hill
Whether it extends beyond the hill depends on whether it also rains behind the hill. So the brain might sometimes be right here.sophiecentaur said:(your brain tells you that it can't be behind the hill!)
The term "virtual image" makes no sense in the case of a rainbow, because there is no focused virtual image of the sun, like in the case of a simple mirror.sophiecentaur said:The mirror that you gaze at yourself in also has a defined position, on the wall. That doesn't mean that your (virtual) image appears in that position.
And neither is a water droplet a simple mirror. And a single water droplet doesn't produce a rainbow, the collective of many water droplets does. And within that collective there is a subset for each each color which forms a cone. It's that cone determines where you see the rainbow, not some "virtual image" of the sun.sophiecentaur said:The mirror is not a projector screen and neither is a water droplet.
There is focussing involved in seeing anything. That is why your eyes have lenses.sophiecentaur said:There is no focussing involved in order to see a virtual image.
Yes, assuming a spherical raindrop the real image for the reflection on the inner surface is in the raindrop. (I had a typo in my previous post, calling it "virtual"). But the key point I was making is, that there is no distinct virtual image here.sophiecentaur said:My issue is that you are claiming that there is an image 'in' the raindrops
What is nonsense, is your claim that a virtual image is somehow produced here. A concave mirror cannot produce a virtual image of an object which is placed outside of the mirrors focal length.sophiecentaur said:This is nonsense which you will discover (using schoolboy ray tracing) when you try to draw a diagram of what goes on. When you have failed, take a look on Wiki or any of the other explanations you can find.
A.T. said:Each water droplet produces a real image of the sun (for each color), within the droplet itself. But that image is quite irrelevant seeing the rainbow.
I made it pretty clear that the real image inside the raindrop is not relevant for seeing the rainbow. The only reason I even mentioned that image is because you claimed that we see a virtual image.sophiecentaur said:Can you point our where, in the raindrop diagram, there is any focussing of a real image that you could possibly see?
There is no virtual image at all here. Concave mirrors don't create virtual images of objects that are outside of their focal length:sophiecentaur said:I don't claim that a virtual image is formed in the drop.
The sun is hardly inside the focal length of a raindrop.hyperphysics said:Concave Mirror Image
If the object is outside the focal length, a concave mirror will form a real, inverted image.
If an object is placed inside the focal length of a concave mirror, and enlarged virtual and erect image will be formed behind the mirror.
You brought up the concept of "virtual images" which is not relevant here. I just pointed out that the only image here is inside the drop and I said that it is not relevant right in the same post.sophiecentaur said:My problem with reading your posts is that you bring up ideas and then say they are not relevant.
The term "virtual image" that you originally used has a specific meaning which not applicable to a rainbow.sophiecentaur said:I'm afraid the whole point about a rainbow is that it is virtual.
Wrong. The first occurrence of the word "image" in this thread is in your post:sophiecentaur said:It is you who first introduced the idea of focussing and image formation.
sophiecentaur said:A rainbow is a virtual image...
Too vague. Try this:sophiecentaur said:an image as 'something you can see'.
It implies 'not even wrong'. Get back to me when you have drawn the diagram showing how a virtual image is formed for a rainbow.sophiecentaur said:"Vague" doesn't imply 'wrong' in any case.
You continuously ask me to to show some things, that I never claimed. If you have a question about something that I actually wrote, quote my statement, explain how you understand it and your objection to it. (Just as I do with your statements)sophiecentaur said:I actually asked you first to show me a proper diagram showing your argument
Every water droplet creates a cone of reflected 'red' rays, which are not all parallel. The red rays that form the red arc in the eye also obviously not parallel, because have to cross in the eye. So which red rays are "all parallel" again?sophiecentaur said:That means that the 'red' rays (of around the same wavelength) are all parallel.
No. Not even the rays reflected by one single drop of the same color are all parallel. They form a cone with the drop in the apex and the line drop-sun as axis.sophiecentaur said:the rays of the same colour from adjacent drops are parallel.
sophiecentaur said:You wanted a quote from one of your posts: Part of Post 7:
The water drops that send light of a certain color to your eye have a well defined position (DIRECTION, ACTUALLY). They form a cone surface with your eye in the apex, and an axis patallel to the sun rays.
It doesn't just appear to be in front of a distant hill. It is in front of it, if the rainy area is closer than the hill. "
That's what I wanted you to justify.
That's completely backwards. If all rays for one wavelength that hit your eye were parallel, you would not see a bow, bur rather a point in the distance.sophiecentaur said:There is only one direction for one wavelength. That is why the bow appears at all.
Quote my statement, ask a question about it or explain how you understand it and give your objection to it.sophiecentaur said:Are you saying that you cannot justify your statement(s) in that quoted post?
Not really. You fail to point out what you think is wrong with my statements, or how you understand (or misunderstand) them. When I have a problem with something you said, I try to clarify it. For example:sophiecentaur said:You understand perfectly well what I want.
What exactly do you mean by "all" here?sophiecentaur said:That means that the 'red' rays (of around the same wavelength) are all parallel.
That's just a semantical issue. When explaining the phenomenon that the OP described (apparently approaching the base of the rainbow) it is practical to consider the intersection of the volume that currently reflects light into the eye with the ground and other obstacles. If you don't like calling that volume the "rainbow" as I did for simplicity, that is fine with me. We can call it something else.sophiecentaur said:your statement that the rainbow 'is' where the drops are, is wrong.
You were not even able to say how you technically define "image" here. You didn't like the http://en.wikipedia.org/wiki/Virtual_image" but provided no alternative reference nor a diagram showing how it applies to a rainbow.sophiecentaur said:I have told you a good reason for saying that the image ...
See above. The grounds is the intersection of the volume that currently reflects light into the eye with the ground and other obstacles.sophiecentaur said:I am asking you for the grounds to justify that bit in bold, in the earlier post.
No, that's not what it means. "Deviated exactly the same amount" means that they all have the same angle to the incoming sun rays. So for each drop they form a cone with the drop at the apex, that opens towards the sun. Rays forming a cone are not all parallel to each other.sophiecentaur said:Red rays of the same wavelength (say 800nm) are deviated exactly the same amount by all water drops.That means that they will all be parallel to each other.
I described the volume that currently reflects light into the eye in post #3 already.sophiecentaur said:Semantic? It's what you wrote and, if it were just a semantic issue, why didn't you mention it ten years ago?
If by "other visual clues" you mean obstacles (like the ground) intersecting the cone, see my post #5sophiecentaur said:I kept saying that it was other visual clues that 'told you' the rainbow was in the cloud. Now you seem to be agreeing. Why not agree earlier?
That is just vague gibberish. The "image of an object" as used in optics is a well defined geometrical construct. I don't see how the rainbow is a image of the sun. The sun could be a cube, and the rainbow would still be round.sophiecentaur said:An Image is something you see.
Can then you post a link to a diagram that specifically shows how the rainbow is an image of the sun?sophiecentaur said:No need for me to do this because the web is full of such diagrams.
How is that relevant? You don't see the light coming from all the drops on a radius of the cone. You just see the light coming from all the drops on the surface of the cone. And those rays are not parallel.sophiecentaur said:If you read carefully you will see that I referred to all drops on a radius from "that cone" deviate the 800nm rays by the same amount.
I don't even know what exactly your idea is, because you just throw around with red herrings, instead of explaining it. But given that you eventually manage to show how the rainbow is an image of the sun at infinity: How does this actually help to address the OP question, about the visual effect of approaching the rainbow?sophiecentaur said:deliver a crushing blow to my ideas
Well, by that logic even a cloud is an "image of the sun": The water drops are just smaller and there is more of them so there is more dispersion, diffusion, more complex reflections. But if what is produced is not an image of the sun, then perhaps you could tell me at what water droplet size the light that you see stops being an image of the Sun.sophiecentaur said:The raindrops are an equivalent to the mirrors but they happen to have dispersive properties and a peculiar geometry that introduces a more complicated rule to what happens to the light. Rings are produced, of different colours. If what is produced is not an image of the sun, then perhaps you could tell me at what stage in all of this, the light that you see stops being an image of the Sun.
I personally wouldn't call halos "identifiable images of the Sun", because I cannot identify the sun in them. There is no clear correspondence between points of the object, and points of the image here. Otherwise, how do you define "identifiable". The transition to a diffuse cloud is smooth here.sophiecentaur said:Clouds (water and ice) can produce identifiable 'images' in the form of halos and sundogs. Who would not call them images of the Sun?
I agree that when you move laterally, the rainbow behaves like it was an object at infinity. But is not the situation the Neveos was interested in (driving towards the base of the rainbow). It also doesn't help to explain the effects the Neveos was asking (approaching the base).sophiecentaur said:What is more important is the position of this image. You do not seem to want to discuss this more important issue because you are not prepared to see how parallax is the basis of position placing.
I explained that this real image is not relevant for seeing the rainbow in the very same post I first mentioned it.sophiecentaur said:It's a shame that you never did provide an explanatory diagram that shows how an actual image is formed 'in' the water drops
Where did I ever say, that the effect of approaching the base of the rainbow works without obstacles? All my explanations (post #5, #7) refer to objects intersecting with the cone of the rainbow.PS: Next rainbow debate here:sophiecentaur said:(i.e. show that, in the absence of any other visual information,)
That was actually my question to you: How do you define an "image of an object" objectively to include a halo, but not include a diffuse cloud? By "objectively" I mean based on in mathematical criteria, not subjective criteria like: "an image is something you can see / identify".sophiecentaur said:So, I repeat my question as to how aberrated can an image be before you would stop calling it an image.
It's irrelevant for seeing in the rainbow as I said many times. I also posted the link already:sophiecentaur said:Where is a "real image" how does it form?
The rain boundary can be at some arbitrary angle to the cone axis, which breaks the symmetry. You eventually don't see the other base at all, until you get into the rain.sophiecentaur said:You say "But if there is only a stripe of rainy area, the rainbow is just a slice of a cone: an actual arc. When you approach the stripe of rain, you will see the near boundary of the arc on the ground coming closer (because it actually is). So even though the arc is not a fixed object, you can get closer to it, and drive trough its base.
This thing is conical, if you are are driving "through the base" then you would also have to be getting closer and closer to the other base where the other side of the bow is, too, because of symmetry. (You have to be on the axis of the cone at all times.)
If you keep the 42° angle to the sun it will not move to one side.sophiecentaur said:You drive at the base and it just moves to one side to avoid you.
I meant: Move at 42° to the sun rays, which are almost horizontal. I see nothing that would stop me from doing so.sophiecentaur said:You can't "keep the 42degrees angle to the sun".
