Exploring E-e Repulsion: Stability of Half and Full P Sub-Shells Explained
  • Thread starter Thread starter htneT
    Repulsion
htneT
I am fully aware that a half filled p sub-shell is stable due to no repulsion as electrons first occupy the orbitals singly before pairing up according to Hunds rule, why is that however a fully occupied p sub-shell with 6 electrons is also considered stable? Where as a filled s sub-shell with 2 electrons is said to undergo e-e repulsion, hence the I.E value of He is less than that of Hydrogen's I.E by a factor of 2 (90% to be exact).
In short: Why is a full p sub-shell with 6 electrons not said to undergo e-e repulsion (considered stable), whereas a full s sub-shell with 2 electrons is said to undergo e-e repulsion (unstable).
The ionization energy of Helium is a little less than twice that of atomic hydrogen, i.e. helium is more inert than atomic hydrogen.
See the table of values here.
Doesn't it have to do with e-e repulsion?
Does what have to do with electron-electron repulsion? You said that helium has a lower ionization energy than helium, which is not the case. Similarly you are talking about p sub-shells but only referring to hydrogen and helium, which only have half and fully filled 1s sub-shells respectively.
My main question is why is a full p sub-shell considered stable, whereas a full s sub-shell considered unstable and its electrons undergo e-e repulsion?
Each electron in a multi-electron atom will of course experience e-e repulsion regardless of which subshell the electron under consideration occupies.
What is the measure of stability/instability you are using, I.E.? Ionization energy is not only determined by the number of electrons present in the atom, but also by the nuclear charge.
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
Is it possible, and fruitful, to use certain conceptual and technical tools from effective field theory (coarse-graining/integrating-out, power-counting, matching, RG) to think about the relationship between the fundamental (quantum) and the emergent (classical), both to account for the quasi-autonomy of the classical level and to quantify residual quantum corrections? By “emergent,” I mean the following: after integrating out fast/irrelevant quantum degrees of freedom (high-energy modes...
