Can We Fly Faster Than a Train?
Flying over a moving train at the speed of the train does not allow the plane to outrun it due to the relative motion of the Earth's atmosphere. The plane's speed is measured relative to the Earth's surface, which is also moving with the atmosphere. When a plane travels at 920 km/h westward from India, it effectively moves 920 km in one hour relative to the Earth's surface, despite the Earth's rotation. Higher altitudes reduce air drag, allowing aircraft to travel further with less fuel, making sub-orbital flights potentially more efficient. However, such flights would require different propulsion systems, like rockets, due to the thin atmosphere at those heights.
abushaheer
if we fly over a moving train at the speed of train can we out run it?? it not, how come we fly at 255m/s when Earth is rotating at 460m/s and we reach from paris to america
Astronomy news on Phys.org
The plane is moving at 255 m/s relative to the surface of the Earth. An observer not rotating with the Earth would see the plane as flying at 715 m/s if it is traveling east or 205 m/s if it is traveling west.
Dear drakkith,
earth rotation as i understand, means India will move relative to atomosphere from point a to point b at 1656km/hr. in the same atmosphere a plane start from India at 920km/hr west ward. how it reachs let's say africa when plane is at half the speed of earth.
India or anywhere else is NOT moving relative to the atmosphere.
The Earth's atmosphere rotates along with the Earth's surface, at the same speed, more or or less.
Small local differences are what we call 'wind'.
A plane in the atmosphere is therefore also rotating along with the the rotation of the planet,
and in addition to that the plane also has a given air speed and direction.
A plane flying at 1000kph either east or west or in any direction will travel 1000km in one hour RELATIVE TO THE EARTH'S SURFACE.
We don't calculate the speed of the plane relatively to some fixed point in space outside of the Earth because that has no practical value whatever.
On a somewhat related topic - what exactly are the physics that allow an aircraft to cover large distances in shorter times the higher they go (proposed sub orbital flights)
Is it because at those heights they are escaping some of the atmosphere? Or is it the higher one gets the greater his (or her) speed relative to the surface below is?
Your first guess is correct.
The atmosphere at a typical cruising altitude for a jet is very much thinner than it is at sea level.
The aircraft therefore experiences much less 'drag' (air friction basically) and so it is effectively able to travel further with a given amount of fuel.
A 'sub-orbital' flight would probably still encounter a small amount of very thin air, but yes it would in principal be even more fuel efficient.
However such an aircraft could not use regular turbine engines where there is so little air, it would need to use rockets or some kind of ramjet, which I imagine would be less efficient in use of fuel than a turbine
This thread is dedicated to the beauty and awesomeness of our Universe. If you feel like it, please share video clips and photos (or nice animations) of space and objects in space in this thread. Your posts, clips and photos may by all means include scientific information; that does not make it less beautiful to me (n.b. the posts must of course comply with the PF guidelines, i.e. regarding science, only mainstream science is allowed, fringe/pseudoscience is not allowed). n.b. I start this...
Asteroid, Data - 1.2% risk of an impact on December 22, 2032. The estimated diameter is 55 m and an impact would likely release an energy of 8 megatons of TNT equivalent, although these numbers have a large uncertainty - it could also be 1 or 100 megatons. Currently the object has level 3 on the Torino scale, the second-highest ever (after Apophis) and only the third object to exceed level 1. Most likely it will miss, and if it hits then most likely it'll hit an ocean and be harmless, but...
