Earth's Magnetic Field: Why Doesn't It Lose Its Properties?
The Earth's magnetic field remains stable despite high core temperatures, which exceed the Curie point for iron and nickel, due to its unique generation mechanism involving electric currents rather than permanent magnetism. Unlike typical magnets that lose their properties at high temperatures, the Earth's magnetic field is sustained by dynamo action in its molten outer core. Discussions emphasize the distinction between magnetic fields generated by electric currents and those from permanently magnetized materials, highlighting the intrinsic properties of electrons. The gyrofactor differences between these types of magnetization further illustrate this complexity. Understanding these principles is crucial for comprehending why the Earth's magnetic field does not diminish under extreme conditions.
Luiz Felipe Ramos
We know that when a magnet is exposed to high temperatures, it loses its magnetic properties. Why then does the Earth's magnetic field behave differently? That is, why doesn't the Earth lose its magnetic properties? According to BBC News Brasil, the core temperature is around 6000 ° C, higher than the Curie point for iron and nickel components.
https://www.bbc.com/portuguese/noticias/2013/04/130428_terra_temperatura_nucleo_sol_rw - Access date: 07/02/2021.
Thanks for listening!
How can there be a magnetic field from a copper coil when copper doesn't even have a Curie temperature?
Likes jim mcnamara, nasu, Luiz Felipe Ramos and 1 other person
PeroK said:
All magnetic fields are caused by electric currents, of one form or another.
I think magnetic fields from permanently magnetized materials should be excluded. Yes, one can use magnetization currents to model such fields but one has to be careful not to take this idea literally. My concern is that one might lose sight of the magnetic moment of the electron as one of its intrinsic properties.
Likes Luiz Felipe Ramos and vanhees71
You quoted @PeroK
But I don't understand if you are arguing against his link ( which is appropriate for the thread) or what your point is ?
That's underlined by the fact that the gyrofactor is around ##2## for the intrinsic magnetization of the electron due to its spin (which is a result of minimal coupling of the em. field and can be derived both within relativistic (Dirac equation) and non-relativistic (Pauli equation) when the "minimal coupling" is done right ;-)).
For a magnetization due to a current the gyro factor is 1.
davenn said:
You quoted @PeroK
I was not arguing against the link. I was trying to clarify to OP that, in a permanent magnet below the Curie point, the existing magnetic field is not generated by currents of the charge transport variety. My objection was to the sweeping use of "all" as in "All magnetic fields are caused by electric currents".
Likes vanhees71 and Charles Link
