Earth's velocity wrt CMB gives the centre of the universe?
To accurately apply Hubble's law, the Earth's velocity relative to the cosmic microwave background (CMB) must be subtracted from galaxy velocities. The Earth moves with respect to the CMB due to local variations, despite the uniform expansion of space. This motion does not imply a special center of the universe; rather, all galaxies perceive themselves as nearly stationary relative to the CMB. Observations show isotropy in the CMB, supporting the idea of a homogeneous universe without a center. Therefore, the Earth's velocity does not contradict the assumption of a centerless universe.
Happiness
Alan Guth mentioned in his lectures that to get the accurate linear relationship of Hubble's law, we need to subtract the velocity of the Earth with respect to the cosmic microwave background (CMB) when calculating the velocity of galaxies.
Question 1:
If space is expanding uniformly throughout, why does the Earth move with respect to CMB?
Question 2:
If the Earth is moving at a velocity with respect to CMB, then doesn't this mean there is a special point that we can consider the centre of the universe? Divide the Earth's velocity by the Hubble's parameter, we will get a displacement vector, which is the vector that points from the centre of the universe to the Earth. Doesn't this contradict the assumption that the universe has no centre?
Guth's lecture:
Space news on Phys.org
Because Earth is not at rest with respect to the comoving coordinates. There is going to be local variations just as there are local variations of velocities in a fluid.
No. Definitely not. There is simply no logic in this statement.
If you are moving with respect to an isotropic backround, you see something very specific, a blue shift in one direction and red shift in the opposite one, and once you correct for this (assuming this is due to proper motion), you recover the isotropic background - nothing of the sort will show up if the background isn't isotropic.
So the CMB observations provide both a measure of Earth's motion relative to the background, and the evidence that this background is isotropic.
And large scale homogeneity with no center is the simplest assumption that explains this isotropy.
No, because those galaxies that are receding from us at huge redshifts also see themselves as barely moving with respect to the CMB, just as we see ourselves barely moving with respect to the CMB. By 'barely' I mean that our velocities are a tiny fraction of c relative to a nearby frame that is considered stationary with respect to the CMB. In other words, those galaxies receding from us do NOT measure a huge difference in the CMB between different parts of the sky.
https://en.wikipedia.org/wiki/Recombination_(cosmology) Was a matter density right after the decoupling low enough to consider the vacuum as the actual vacuum, and not the medium through which the light propagates with the speed lower than ##({\epsilon_0\mu_0})^{-1/2}##? I'm asking this in context of the calculation of the observable universe radius, where the time integral of the inverse of the scale factor is multiplied by the constant speed of light ##c##.
The formal paper is here. The Rutgers University news has published a story about an image being closely examined at their New Brunswick campus. Here is an excerpt: Computer modeling of the gravitational lens by Keeton and Eid showed that the four visible foreground galaxies causing the gravitational bending couldn’t explain the details of the five-image pattern. Only with the addition of a large, invisible mass, in this case, a dark matter halo, could the model match the observations...
Hi, I’m pretty new to cosmology and I’m trying to get my head around the Big Bang and the potential infinite extent of the universe as a whole. There’s lots of misleading info out there but this forum and a few others have helped me and I just wanted to check I have the right idea. The Big Bang was the creation of space and time. At this instant t=0 space was infinite in size but the scale factor was zero. I’m picturing it (hopefully correctly) like an excel spreadsheet with infinite...
