Easier way to get exact sum/avr?
  • Thread starter Thread starter buddingscientist
The discussion focuses on finding the average distance from the bottom and right edges of a box using both summation and integration methods. The user initially calculated the average using approximations and Excel, arriving at values around 1.1478. A more precise approach was suggested, involving integration from 0 to 1, yielding an exact expression of approximately 1.14779. The integration method simplifies the process and confirms that the average can be derived from a Riemann sum. The conversation concludes with an acknowledgment of the effectiveness of integration over messy summations.
buddingscientist
Easier way to get exact sum/avr? [SOLVED, thanks awvvu]
Greetings,
First I will explain what I am trying to do.
I am trying to find the 'average' distance from the bottom and right edges of this box:
http://img174.imageshack.us/img174/8934/okvi7.jpg
Basically (using 11 approximations)
What I am after for is equal to
1 + sqrt (1 + 0.1^2) + sqrt (1 + 0.2^2) + sqrt (1 + 0.3^2)
+ sqrt (1 + 0.4^2) + sqrt (1 + 0.5^2) + sqrt (1 + 0.6^2)
+ sqrt (1 + 0.8^2) + sqrt (1 + 0.8^2) + sqrt (1 + 0.9^2) + sqrt(2)
And then that divided by 11
I've used a nice messy excel spreadsheet to get this to 1000 approximations (1000 little 'slices') to get an average of 1.148001 and also using 5000 slices I get 1.147835
Basically as a summation what I _think_ I am looking for is (1000 slices):
\frac{1}{n} \sum_{n=1}^{1000} \sqrt{1^2 + (0.001n)^2}
(that right?)
And extended to an infinite amount of slices:
\lim_{k\rightarrow\infty} \frac{1}{k} \sum_{n=1}^{k} \sqrt{1^2 + (\frac{n}{k})^2}
(is this right/possible?)
What I am looking for is, using integration, or if it is do-able to evaluate that sum, to know if it is possible to get an 'exact' answer for the 'average' distance?
I imagine it would be very similar to the 1.1478 answer above, but I'm looking for more accuracy (basically to whatever precision the infinite sum gives) or if it just happens to equal a nice fraction for me (8/7 which is 1.14285...) or you know.. something nice and round
Thanks for reading, please let me know if you need any more info, or if I have gone wrong somewhere, or any hints to get me on the right track, etc.
Mathematics news on Phys.org
You can set it up as an integral.
Let's place the bottom-left corner of the square at the origin. The distance from the top-left corner to any x is \sqrt{1+x^2}. And we want to integrate from x = 0 to x = 1.
I stuck it into integrator and the antiderivative is \frac{1}{2}(x \sqrt{1 + x^2} + arcsinh(x)). Plugging in our limits gives \frac{1}{2}(\sqrt{2} + arcsinh(1)) \approx 1.14779. It's a pretty unexpected exact expression.
I think with some prodding, your sum can be turned into a Riemann sum and you'll get the same results as setting it up as an integral directly.
edit: The integral and final expression should be divided by its length (1) to find the average.
Thanks very much !
I knew there would be a simpler way through integrating than my messy summations.
Could I ask what you mean by "It's a pretty unexpected exact expression" ? (Just out of interest)
Thanks again
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Imaginary Pythagorus'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
