Solving Equations with Multiple Variables
  • Thread starter Leaping antalope
In summary, the conversation discusses solving a system of equations with four variables. The suggested method is to create equations in the form of d=... and use elimination to obtain two equations with two variables. Then, using the fifth equation, one can create another equation with two variables and use elimination again to solve for the remaining variables. This process is repeated until all four variables are obtained.
Leaping antalope
44
Could someone solve these equations for me? It seems complex, but I believe there is a easy way to find out a, b, c, and d...
(1) 8a+4b+2c+d=11
(2) 27a+9b+3c+d=44
(3) 64a+16b+4c+d=110
(4) 125a+25b+5c+d=220
(5) 216a+36b+6c+d=385
Find a, b, c, and d.
Thanks~
At first glance it appears you have too many equations.
Other than that, why don't you just try elimination?
Also, some of them can be divided into smaller numbers to.
Some are also proportional and for that reason you can get ride of one equation.
Honestly take it nice and slow, so you make know mistakes, and you'll get it.
Note: Soon you'll learn about matrices and thank "godmath" for it.
Keep multiplying the equations by whole numbers to cancel out variables by subtraction like 2-1=A 3-2=B 4-3=C
then result B-A=X C-B=Y
Y-X
that should leave you with one varible equals a number
Solution
(1) 8a+4b+2c+d=11
(2) 27a+9b+3c+d=44
(2)-(1)= (A)
(3)-(2)= (B)
(4)-(3)= (C)
(A)= 19a + 5b + c = 33
(B)= 37a + 7b + c = 66
(C)= 61a + 9b+ c = 110
(B)-(A)=(X)
(C)-(B)=(Y)
(X)= 18a + 2b = 33
(Y)= 24a + 2b = 44
(Z) = (Y)-(X)
(Z)= 6a=11
a=11/6
therefore
by Equation (X)
(X)= 18a + 2b = 33
18(11/6)+ 2b = 33
b=0
therefore
by equation (A)
19a + 5b + c = 33
19(11/6) + 5(0) + c = 33
c=-11/6
thefore by Equation 1
8a+4b+2c+d=11
8(11/6)+4(0)+2(-11/6)+d=11
d=0
Summary
[tex] a=11/6 [/tex]
[tex] b=0 [/tex]
[tex]c= -11/6[/tex]
[tex]d= 0[/tex]
indeed you need x number of equations to solve for x number of variables
in this case i needed 4 equations since there were four variables being solved for
a,b,c,d
Take all of the equations and make them of the form d= ...
Then, you can put the two non d sides of the equation together to create 2 pairs in which d is elimintated entirely.
You can repeat with these 2 equations to eliminate one of the other variables. This will leave you with 2 variables.
You can use the 5th equation to start over with one of the other 4, to obtain another formula using 2 variables. Then, add them up to eliminate one of the variables. Once you have the value of one of the variables, you can fill it in the others, and repeat to discover the others.
1. What is the concept of "Easy, but seems complicated"?
The concept of "Easy, but seems complicated" refers to tasks or problems that may appear difficult at first glance, but can actually be broken down into simpler steps or solutions.
2. Why do some things seem complicated even though they are easy?
Some things may seem complicated because they involve unfamiliar or complex terminology, or require specific skills or knowledge that the individual may not possess. Additionally, our perception of difficulty can be influenced by our own biases and assumptions.
3. How can we make difficult tasks seem easy?
To make difficult tasks seem easy, it is important to break them down into smaller, manageable steps and approach them with a positive mindset. Seeking help or guidance from others who are knowledgeable in the subject can also make the task seem less daunting.
4. Why is it important to understand the concept of "Easy, but seems complicated"?
Understanding this concept can help us approach challenges and problems with a more open and positive mindset. It can also help us break down complex tasks into simpler steps, making them more achievable and less overwhelming.
5. Can anyone learn to see things as "Easy, but seems complicated"?
Yes, with practice and a willingness to approach tasks with an open mind, anyone can learn to see things as "Easy, but seems complicated". It may require some effort and patience, but the more we challenge ourselves and break down difficult tasks, the easier it will become to see them in a different light.
15K
