How do I calculate the torque of an eddy current brake?
EricVT
An electromagnetic "eddy current" brake consists of a disc of conductivity \sigma and thickness d rotating about an axis passing through its center and normal to the surface of the disc. A uniform B is applied perpendicular to the plane of the disc over a small area a^2 located a distance P from the axis. Show that the torque tending to slow down the disc at the instant its angular speed is W is given approximately by \sigma*W*d*[B*P*a]^2
I assume that you need to calculate the force on the disc at the small section a^2 and then from this a torque can be easily found. Can you say:
F=q\cdot(E+v \times B)
And since the electric field is motional make this
F=q\cdot(E+v \times B)=q\cdot(v \times B+v \times B)=q\cdot(2v \times B)
v \times B = BPW
F=2qBPW
If so, how do you find the charge enclosed inside of the little region of volume d*a^2? I don't quite see how the conductivity plays into all of this, or where the second factor of B comes from in the solution.
Any help would be appreciated.
I'm bumping this (I hope there's nothing wrong with me doing so). I'm having the exact same problem as well.
Anyone? This problem is due soon, and I'm having trouble getting beyond that point.
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
