Effect of wind speed on running
The discussion focuses on calculating the impact of wind speed on running performance, specifically comparing running at 10 mph against a 15 mph headwind. Key factors include velocity, drag, and inertia, with drag force being proportional to the square of velocity and influenced by cross-sectional area and fluid density. The accuracy of existing calculators, like the one from Run Smart Project, is questioned due to a lack of transparency regarding their underlying data and methodology. It is suggested that while these calculators may provide indicative results, they are unlikely to be perfectly accurate without proper calibration. Overall, the conversation highlights the complexities of quantifying the effects of wind on running speed.
Jank
Hi guys,
I'm an arts undergrad student with very little knowledge of the sort of physics I'm about to ask.
I was wondering if there is a calculation to work out the differentiation between running at a particular speed say 10mph against wind coming towards you at 15mph. As well as it being on flat & say the person being about 60kg and about 1.7 metres tall (average person).
Obviously if there was no wind against you, you would runner faster, and even faster with wind behind you.
Whats the calculation (in layman's terms) to work out the difference?
I've linked some articles below which I've read and tried to understand, I know its something to do with velocity, drag and inertia.
Thanks for taking your time!
http://jap.physiology.org/content/48/4/702
https://www.brunel.ac.uk/~spstnpl/Publications/WindAccuracy(Linthorne).pdf
http://rmseura.tkk.fi/rmlehti/1997/nro2/RakMek_30_2_1997_1.pdf
http://engineeringsport.co.uk/2011/05/04/the-loneliness-of-the-long-distance-physicist/
Just wanted to add that I am a runner and the reason I started thinking about this was because I wondered if this website:
http://runsmartproject.com/calculator/
Has a legitimate way of calculating wind difference.
From what I remember of drag on an object in fluid dynamics ( air is a fluid), the drag force is proportional to the velocity squared with a constant of proportionality which is related to the cross-sectional area and fluid density (but also has some 3D shape dependence because of laminar-turbulent flow effects). Look for calculations of terminal velocities of free falling objects for example. Without knowing how the calculation is actually performed on the website it is difficult to judge how accurate it will be. It is unlikely that such calculations are likely to be absolutely accurate without calibration (to determine the constants of proportionality in the drag force for a given individual) but it is likely that they will be indicative. It would appear that Jack Daniels has tables, presumably of experimental measurements which are used in the calculator, but the website contains no reference to this data or discussion of the theoretical basis on which it is derived. It may be described in Jack Daniel's book, which is not referenced, but is presumably available. A case of insufficient information at this point on which to judge whether the approach is scientifically based and valid.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
