Effective resistance between two points
  • Thread starter Thread starter DarylMBCP
    Points Resistance
The discussion focuses on identifying the effective resistance between two points in a circuit containing three 6-ohm resistors. The participants confirm that the resistors are arranged in parallel, leading to a total resistance of 2 ohms, calculated using the formula for parallel resistors: RTotal = 1/R1 + 1/R2. A key rule established is that series elements share the same current, while parallel elements share the same voltage difference. This method for determining resistor arrangement is applicable to all resistor circuits.
  • Understanding of Ohm's Law
  • Familiarity with series and parallel resistor configurations
  • Ability to interpret circuit diagrams
  • Knowledge of resistance calculations
  • Study the principles of Ohm's Law in depth
  • Learn advanced techniques for analyzing complex resistor networks
  • Explore circuit simulation tools like LTspice for practical applications
  • Review the impact of resistor tolerance on effective resistance calculations
Electronics students, hobbyists, and engineers looking to deepen their understanding of circuit analysis and effective resistance calculations in resistor networks.
DarylMBCP
Hey guys, I'm having a little troublt with rearranging resistors in a circuit to identify which are parallel and which are in series so I can decide how they should be added; RTotal = R1 + R2 or RTotal = 1/R1 + 1/R2.
Taking that each of the three resistors in the circuit shown (diagram attached) has a resistance of 6 ohms, what is the effective resistance between X and Y? The answer key shows that the three are parallel and if that is so, I knw how to calculate the effective resistance to get 2 ohms.
However, I'm not sure how to identify if they are parallel or not from the diagram. Any help is greatly appreciated. Thanks.
One little rule to make that decision is this: series elements have the same current, while parallel elements have the same voltage difference.
Ok, so from the diagram I can see that the three resistors have different current passing through them but have the same voltage difference so the MUST be parallel, right? Is this method standard for all examples? Thanks for the help.
Yes, same voltage means they are in parallel. And I'm pretty sure this method does work for any resistor circuit.
  • · Replies 19 ·
