Effects of heating up different fat acids
The discussion centers on the best oils for frying and deep-frying, particularly examining the "badness" of heating different types of fats. It proposes a function to evaluate the degradation of fats at various temperatures, noting that saturated fats can withstand higher temperatures than monounsaturated and polyunsaturated fats without significant damage. The conversation highlights that saturated fats are less susceptible to oxidation, which produces harmful acids during heating. It also mentions the standard method for assessing the quality of fats through the titration of acids generated during the heating process. The inquiry seeks existing research on this topic, suggesting a resource for further reading on the oxidative stability of different fats.
TriKri
Hello!
The question about which oil that is the best to fry in, or to deep-fry in, should be examined, if it hasn't been already. Is it possible to set up a function b_f(T), where b is the "badness" of heating up a certain kind of fat f to temperture T? For example, saturated fat can be heated up to higher temperatures than monounsaturated fat which can be heated up to higher temperatures than plyunsaturated fat without taking more damage from it. But of course, heating up saturated fat isn't good either.
Chemistry news on Phys.org
I assume that you meant to post a question regarding the quality of fats as a function of heating. Fats are the triglycerides of fatty acids. The standard way to measure 'badness' is by titrating acids produced during the heating process. The acids arise from partial or total hydrolysis of the triglycerides and the action of oxygen upon the unsaturates which ultimately produce lower molecular weight acids. Saturated fats aren't as susceptible to the oxygen I believe.
Is there some big studies made on this topic? Can one see the results from them somewhere?
Thanks!
It seems like a simple enough question: what is the solubility of epsom salt in water at 20°C? A graph or table showing how it varies with temperature would be a bonus. But upon searching the internet I have been unable to determine this with confidence. Wikipedia gives the value of 113g/100ml. But other sources disagree and I can't find a definitive source for the information. I even asked chatgpt but it couldn't be sure either. I thought, naively, that this would be easy to look up without...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
