Can Refrigerators Have Greater Efficiency Than Theoretical Value?
  • Thread starter Thread starter Chronos000
    Efficiency
Chronos000
the efficiency of a fridge is given by n=Q/W but this is actually the coefficient of performance.
normally the efficiency of an engine is n= W/Q.
the result i get for the coefficient of performance is 18.5 and my textbook says real fridges have coefficients of 4 or 5. you would think one over this value would give the actual efficiency. but if you do this then the efficiency of real fridges is greater than the theoretical one.
I clearly don't understand something here. also, can i derive the specific solution for any engine/fridge from a general form?
The measure of efficiency is always output/input. In the case of the engine, you're taking heat Q from the hot reservoir and produce work W, so the efficiency is W/Q. In the case of the refrigerator (no D in refrigerator!), you're doing work W for the goal of removing heat Q from the cold reservoir, so the coefficient of performance is Q/W.
that makes sense. so the idea of getting a percentage efficiency doesn't exist for a fridge?
and I was sure I'd spelt it wrong haha
Right. But you could compare a real refrigerator to a Carnot refrigerator working between the same two temperature reservoirs. The Carnot refrigerator would extract the most heat for a given amount of work, so the fraction Qreal/QCarnot could be seen as a percentage efficiency, in the sense it measures how close the real refrigerator gets to being an ideal one.
thats great, thanks
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
