Efficient Goldbach Partitions Formula with Intuitive Reasoning
  • Context: Graduate
  • Thread starter Thread starter Marchal
    partitions
The discussion revolves around an approximation formula for Goldbach partitions, exploring its accuracy compared to established formulas like Hardy-Littlewood's with the Shah-Wilson correction. Participants engage in technical reasoning, corrections, and refinements of mathematical expressions and notations.
  • One participant presents a new approximation formula for Goldbach partitions, claiming it is nearly as accurate as existing formulas.
  • Another participant identifies a potential typo in the formula and provides a corrected version, suggesting that the original derivation is flawed.
  • A third participant uses Merten's Theorem to argue that the new formula must be adjusted by a specific factor to achieve asymptotic equivalence with Hardy-Littlewood's formula.
  • Subsequent posts highlight multiple errors in the initial presentation, including nonstandard notations and issues with the definitions used.
  • Further critiques address the clarity of the mathematical expressions and the need for more rigorous definitions and symbols.
  • Participants express uncertainty about the validity of certain claims, particularly regarding asymptotic equivalence and the randomness of prime distributions.
Participants do not reach a consensus; multiple competing views and corrections are presented, indicating ongoing debate and refinement of the proposed formula and its derivation.
Limitations include unresolved mathematical steps, unclear definitions, and the dependence on specific notations that may not be universally accepted.
Marchal
Intuitive reasoning has led me to develop a simple approximation, which contains factors different from those used in well knoen formulas. Numerically, "my" formula delivers results, which are almost as accurate, as Hardy-Littlewood`s with the Shah-Wilson correction.
Thanks in advance for any comments
The formula (2) has a typo or is otherwise ill-posed. I trust from the parenthetical comment that the intent is
[tex]\frac12\pi(n)\prod_{3<p<\sqrt n}\frac{p-2}{p-1}[/tex]
Your approximations in (2.1) are off by a factor of about 2.245838. (I'll let you figure out where this came from.) This causes the derivation of (2) to be wrong.
Asymptotically, the ratio of g_alt/g_HL is not 1 but about 1.123. The first factor is 1 + O(1/log n), the third factor is 1 + o(1), and looks to drop off like 1 + O(1/log^2 n). The second factor is where the trouble comes from.
Thank you indeed, CRGreathouse, for signalling this error.
Using Merten's Theorem, I find, that g_alt must be divided by 2*exp(-gamma)=1,122918967...,
with gamma=0,577215664901... being Euler-Mascheroni's constant.
Then, g_alt will be asymptotically equivalent to g_HL
I'm now working on correcting the derivation of (2)
Best Regards - Marchal
Here is a revised version of my article.
I wrote several paragraphs of response but the forum ate it, grr. In short: There are about two dozen errors in the first few pages, but they're mostly minor and correctable. By page 3 you use notations that are not only nonstandard but for which I can't even find any valid interpretation.
Unfortunately your use of ≈ rather than, say, ~ makes your statements non-testable (and even non-falsifiable in a Poperian sense).
Dear CBGreathouse
Thanks for reviewing my text with so much attention!.
In standard notation I should write
n[tex]\neq[/tex]0 (modp) (equation 2a)
q[tex]\neq[/tex]0 (modp) and q[tex]\neq[/tex]n (modp) (equation 2.2.1)
I changed the equivalence symbols, as you suggested (see attachment).
Did I miss uploading the file Goldbach3?
1.2 still has issues. It's C_2 not C_HL and the "<= infinity" should be dropped. (There are rare cases where you want to write "< infinity" for clarity, but this isn't one and certainly "<= infinity" is just wrong.)
2a confuses me; what's the definition of g_alt? If this is supposed to be the definition you need = not ~ (or one of the defined-as symbols, if you prefer).
For congruences you need ≡ ≢ not = ≠ .
Have to go now; might look at p. 3 ff. later.
I still worked on page 3. Here it comes with corrections.
Please ignore my last message. Here comes page3-improved version.
2.2.2 is the first questionable part: you claim that one obtains asymptotic equivalence. (You mark it an estimate, but then write ~.) This heuristic has been well-known for hundreds of years, but a proof is lacking. This is what you'd expect if the primes fell 'randomly', but it's not clear that they do in an appropriate fashion.
Thanks, Greg. I fully agree. Besides, I suspect my deduction to be substantially erronous. I'll need some time to clarify the matter.
Until then
Marchal
Here I am again! For correct formula & deduction, see APPENDIX attached.
  • · Replies 23 ·
  • · Replies 28 ·
  • · Replies 0 ·
  • · Replies 16 ·
