Efficient Numerical Method for Inverse Integration with Known Constants a, b, c
  • Thread starter Thread starter jimbo_durham
    Integral Inverse
The discussion focuses on the challenge of numerically computing the inverse of a complicated integral, specifically needing to find x given a known value of d, where d is defined as the integral of a function f(x). The user is currently using C++ and Simpson's rule for integration but seeks an efficient iterative method to guess x and refine that guess based on the output of the integral. There is mention of a potential "press" method, which may involve finding the roots of an equation related to the integral's value. A proposed approach involves solving a differential equation derived from the relationship between y and x, but the user is unsure how to implement it. The discussion highlights the need for effective numerical methods for inverse integration in complex scenarios.
jimbo_durham
I have a complicated integral which i need to compute numerically. I can do this in C++ using a version of Simpson's rule. I also need to compute the inverse of this integral (presumably this is what it is called) ie i have
d=integral(f(x)dx)
and i need to be able to compute x given a value of d.
The function f(x) is too complicated to simply rearrange, so i need an iterative way of guessing x, running it in the program, seeing what value of d is given, and then improving my guess of x until i reach my starting d value.
This seems on the surface to be a simple iteration problem, however i cannot find an efficent way of doing this.
Can anyone tell me of a nice way of solving this problem (and even if it is called an 'inverse integration' or not?) and if there is a name given to the numerical method of solving it.
It has been mentioned that there is a 'press' method however i can find no mention of this. Prehaps it involves finding the roots of an equation which takes the value of the integral evaluated at some guessed x, and the roots give the point where the guessed x corresponds to the known d, thus solving the problem? does this ring any bells?
sorry for the long post, thanks in advance for your help
Mathematics news on Phys.org
Well, one way would be:
Let:
y(x)=y(0)+\int_{x_{0}}^{x}f(t)dt
Or, that is:
y=y_{0}+\int_{x(0)}^{x(y)}f(t)dt
Differentiating the latter expression with respect to y yields:
1=f(x(y))\frac{dx}{dy}
That is, you may solve the following differential equation numerically:
\frac{dx}{dy}=\frac{1}{f(x)}, x(y_{0})=x(y_{0})
i am not sure how to apply that, i think it is worth me giving you the integral;
<br /> \begin{equation}<br /> <br /> d_{M}=c_{1}\cdot sinh\left[c_{2}\int^{b}_{a}\left[\left(1+z\right)^{2}\cdot\left(1+c_{3}\cdot z\right)-z\cdot\left(2+z\right)\cdot c_{4}\right]^{-\frac{1}{2}}dz\right]<br /> <br /> \end{equation}<br />
i am trying to find z given a value of d_{M}.
note in formula, a, b, c are known constants
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
