Eigenfunction of a spin-orbit coupling Hamiltonian
8 replies · 4K views · last reply
IanBerkman
Dear all,
The Hamiltonian for a spin-orbit coupling is given by:
[tex] \mathcal{H}_1 = -\frac{\hbar^2\nabla^2}{2m}+\frac{\alpha}{2i}(\boldsymbol \sigma \cdot \nabla + \nabla \cdot \boldsymbol \sigma)[/tex]
Where
[tex] \boldsymbol \sigma = (\sigma_x, \sigma_y, \sigma_z)[/tex]
are the Pauli-matrices.
I have to find the eigenfunctions of this equation. However, I am not sure how to interpret the part: [tex] \nabla \cdot \boldsymbol \sigma[/tex]
The Pauli-matrices are 2x2 matrices containing only constants, does this mean this term equals zero?
Thanks in advance.
Ian
IanBerkman said:
Dear all,
Where
Thanks in advance.
Ian
I think the nabla symbol ∇ along with σ means derivative of σx with respect to x, derivative of σy with respect to y, and derivative of σz with respect to z.
Can you see that:
## \nabla \cdot \sigma =\begin{pmatrix} 0 & \frac {\partial} {\partial x}\\ \frac {\partial} {\partial x}&0\end{pmatrix}+\begin{pmatrix} 0 & \frac {-i\partial} {\partial y}\\ \frac{i\partial} {\partial y}&0\end{pmatrix}+\begin{pmatrix} \frac {\partial} {\partial z} & 0\\0 & \frac {-\partial} {\partial z}\end{pmatrix}\\ ## ?
Fred Wright said:
Can you see that:
It appears mostly correct.
However, the derivative of a constant is equal to 0.
Yeah that was part I was most confused of:
Does it mean it:
(1) takes the partials of the components (constants) inside the Pauli matrices
or
(2) the partials take the places of the constants in the matrices?
In the first case I would say the term becomes zero, the second case gives indeed the answer of Fred Wright.
The solution I took was using the product rule
[tex] \boldsymbol\sigma \cdot \nabla \psi + \psi \nabla\cdot\boldsymbol\sigma = \nabla \cdot (\psi \boldsymbol\sigma)[/tex]
And solved the RHS with the plane-wave solution ##\psi = e^{i k \cdot r}##
Remarkable is how
##\boldsymbol \sigma \cdot \nabla e^{ik\cdot r} = \begin{pmatrix}
ik_z & ik_x+k_y\\
ik_x-k_y & -ik_z
\end{pmatrix}e^{ik\cdot r}## and
##\nabla \cdot (e^{ik\cdot r} \boldsymbol \sigma) =
\begin{pmatrix}
ik_z & ik_x+k_y\\
ik_x-k_y & -ik_z
This concludes that the term ##
e^{ik\cdot r} \nabla \cdot \boldsymbol \sigma = 0\\
and therefore, if I did nothing wrong
Your Hamiltonian appears to be a somewhat abstruse variant of the Rashba effect which is a model of a 2d solid coupling electronic quasi-momentum to spin. In this model symmetry is broken by a transverse time independent E field, ##-E_0\hat z##. Due to relativistic corrections an electron moving with velocity v in the electric field will experience an effective magnetic field B(the "orbital" moment). Google Rashba effect for a derivation. The upshot is ## H_R = \alpha(\mathbf \sigma \times \mathbf k) \cdot \hat z. ## Where ##\mathbf k = \frac {\nabla} {i}## is the quasi-momentum. Now rewritten with the quasi-momentum, the ##\sigma## term in the Hamiltonian becomes:
## \frac { \mathbf \nabla} {i} \cdot \mathbf\sigma = \mathbf k \cdot \mathbf\sigma= \begin{pmatrix} k_z & k_x - ik_y\\ k_x + ik_y & -k_z\end{pmatrix}##.
The vector inner-product commutes so, ## \mathbf k\cdot \mathbf \sigma = \mathbf \sigma \cdot \mathbf k##. I assert that this can only be physical if ##k_z=0## because the symmetry breaking field is along the z-axis. Thus we write the Hamiltionian:
##\frac {ħ^2k^2\sigma_0} {2m}+ \alpha( \mathbf \sigma \cdot \mathbf k)= \begin{pmatrix} \frac {ħ^2k^2} {2m} & \alpha(k_x - ik_y)\\ \alpha(k_x + ik_y) & \frac {ħ^2k^2} {2m}\end{pmatrix}##,
where ##\sigma_0## is the 2x2 unit matrix. You can diagonalize this matrix to find the eigenvectors and eigenvalues which lift the degeneracy of the conduction band due to the spin-orbit interaction.
Thank you, the Hamiltonian looks exactly the same as the Hamiltonian I have obtained, except for a ##\alpha/2## factor.
I have plotted the energies as function of ##k_x## and it looks like the Rashba effect, which should be no surprise.
I think I have enough information to conclude a right answer about this problem, thank you all.
