Eigenfunctions of an Integral Operator
The discussion revolves around finding eigenvalues for the integral operator defined by Kf(t) = ∫_0^1 (1+st) f(s) ds. Initial attempts to convert the problem into a differential equation were unsuccessful, leading to exploration of eigenfunctions of the form f(t) = t + a. A system of equations was derived, yielding one eigenvalue (λ = 1.267591879) and a corresponding constant (a = 1.868517092), raising concerns about the uniqueness of this eigenvalue. Participants noted that the integral operator likely has more than one eigenvalue, suggesting a quadratic equation might provide additional solutions. The conversation emphasizes the need for a thorough algebraic approach to uncover all possible eigenvalues and eigenfunctions.
Kreizhn
If there are any eigenvalues for the following integral operator, calculate them
Kf(t) = \int_0^1 (1+st) f(s) \ ds
I've tried making this into a differential equation, to no avail. I've also just tried solving the equation Kf(t) = \lambda f(t) though that also didn't lead anywhere. I'm not sure if there's some special way of attacking problem like this. Does anybody have any ideas?
It's a lot easier than you are think it is. Your integral expression is a linear function of t, no matter what f is.
not too sure.. but how about noticing the t depndence of the function... does the fact
\int_0^1 f(s) ds
and
\int_0^1 sf(s) ds
are constants help..
I had tried looking for eigenfunctions of the form a + bt but for some reason got an inconsistent system of equations. I'll go back and look at it again.
i haven't tried, but for non-zero b
(a+bt) = b(a/b+t)
so if (a+bt) is an eigenfunction, then so is (a/b+t) = c+t which ma be easier to deal with
So if try a function of the form f(t) = t + a and try K f(t) = \lambda f(t) I get the following system of equations
\begin{align*}<br /> \frac13 + \frac a2 &amp;= \lambda \\<br /> \frac12 + a &amp;= \lambda a<br /> \end{align*}<br />
I can solve this to get a = 1.868517092, \lambda = 1.267591879. But it seems odd that an integral operator would only have one eigenvalue in it's spectrum. Furthermore, how can I be sure that this is exhaustive? How would I find other eigenvalues and eigenfunctions?
the only other option is a constant, which i don't think works as you end up with a t dependence
Indeed, so you're saying that the only possible eigenfunctions are of the form f(t) = t+a since for all other functions, Kf(t) will be first order polynomial in t.
Don't you get a quadratic equation in lambda? Aren't there two eigenvalues?
Yes. I was being lazy an had plugged this into a Maple to solve numerically. But it isn't hard to do algebraically. I realized this, but figured the thread was dead so it wasn't important to post it :P
Sure. Just checking...
  • · Replies 105 ·
