Understanding Eigenvalues of a Matrix
The discussion centers on the confusion regarding the properties of a non-invertible matrix and its eigenvalues. Participants clarify that a singular matrix cannot have an inverse, as demonstrated through a contradiction involving the mapping of vectors in a two-dimensional space. The matrix in question is shown to yield a one-dimensional image, confirming its non-invertibility. Additionally, the eigenvalues of the matrix are identified as -2 and -3, with corresponding eigenvectors satisfying the eigenvalue equations. Overall, the conversation emphasizes the relationship between matrix invertibility and eigenvalues.
member 731016
Please see below
Please see below
For this,
I am confused by the second line. Does someone please know how it can it be true since the matrix dose not have an inverse.
Many thanks!
Why do you think it is true?
Likes member 731016
ChiralSuperfields said:
Homework Statement: Please see below
Relevant Equations: Please see below
For this,
Me, too. I don't know what this means. ##A\cdot 0=0## no matter whether ##A## is invertible or not.
Many thanks!
The matrix doesn't have an inverse. If we want to prove this by contradiction then we assume it has an inverse. Say the matrix is ##A.## Then ##A## maps the entire space ##\mathbb{R}^2## onto itself: ##A\cdot v= w.## Now, if we set ##v=\begin{pmatrix}x\\ y\end{pmatrix}## then ##A\cdot v=\begin{pmatrix}-x+2y\\-x+2y\end{pmatrix}.## But this means that both coordinates of ##w## are the same and we have no chance to get any other vector with different coordinates. So the image of ##A## is one-dimensional, not two-dimensional, so it cannot be invertible.
You can also argue with a vector in the kernel of ##A##. Can you name one for which ##A\cdot v=0## while ##v\neq 0?##
Likes member 731016
The statement in the first two lines is vacuously true: if a singular matrix has an inverse, then the equality holds. The equality has no meaning because ##^{-1}## doesn't exist for this matrix.
Likes member 731016
The part in the lower half of the image doesn't make much sense in the context of what you're asking.
You have ##\begin{bmatrix} 1 & -2 \\ 1 & -2\end{bmatrix} = A - 2I##
If you work this out, you find that ##A = \begin{bmatrix} -1 & -2 \\ 1 & -4\end{bmatrix}##.
Since you're asking about eigenvalues for a matrix (presumably A, above), it turns out that the eigenvalues are -2 and -3. This means that for one eigenvector ##x_1##, ##Ax_1 = -2x_1##, and for the other eigenvector ##x_2##, ##Ax_2 = -3x_2##.
Likes member 731016
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
