What are the eigenvalues of L operators?
I'll have to think a little bit more about it. You can check your calculation by looking at the commutator [Lx, Ly] and see if it's equal to i hbar L_z. That would be another check.Hi. Thanks for posting them, I did not feel like typing them all!You are riht except for one tiny mistake: the coefficient of the Y_10 is \frac{1}{\sqrt{2}} , not \sqrt{2} . Now, if you apply L_x written as a differential operator on that expression (that will be long!) you should find that it's an eigenstate with the expected eigenvalue. But if you want to just make
El Hombre Invisible
692
Hi
We're given the operators Lx, Ly and Lz in matrix form and asked to show that they have the correct eigenvalues for l=1. Obviously no problem determining the values and Lz comes out right, however we've never actually seen the e.v.s for Lx and Ly.
I tried finding the eigenvalues in the wave formulation for Lx and Ly using the operators in polar spherical co-ords:
[tex] L_{x} = i\hbar(sin\phi\frac{d}{d\theta} + cot \theta cos \phi \frac{d}{d\phi}) [/tex]
[tex] L_{y} = i\hbar(-cos\phi\frac{d}{d\theta} + cot \theta sin \phi \frac{d}{d\phi}) [/tex]
Dealing with l = 1, so my spherical harmonics are in one of two forms:
[tex] Y_{1,0} = (\frac{3}{4\pi})^{1/2}cos\theta [/tex]
[tex] Y_{1,\pm1} = \mp(\frac{3}{8\pi})^{1/2}sin\theta exp(\pm i \phi) [/tex]
Well, applying the operators to the wfs gives me nothing like an eigenvalue. For instance:
[tex] L_{x}Y_{1,0} = -i \hbar sin \phi tan \theta Y_{1,0} [/tex]
Anyone see where I'm going wrong, or just happen to know offhand the eigenvalues for Lx and Ly?
Cheers,
El Hombre
El Hombre Invisible said:
Hi
[tex] L_{x} = i\hbar(sin\phi\frac{d}{d\theta} + cot\thetacos\phi\frac{d}{d\phi}) [/tex]
[tex] L_{y} = i\hbar(-cos\phi\frac{d}{d\theta} + cot\thetasin\phi\frac{d}{d\phi}) [/tex]
It's not wrong because the Y_lm are simply NOT eigenstates of L_x and L_y! The eigenstates of L_x and L_y are linear combinations of the Y_lm. But if the operators were given to you as matrices in the first place, why do you use differential operators? Simply find the eigenvalues of the matrices you were given !
Hi
First off, those LaTex codes didn't quite come out the way I intended. Second, like I said I had no problem finding the eigenvalues of the matrix operators. The problem is in verifying them. I get the same eigenvalues for each matrix, i.e. mh, with the three possible values of m for l=1. The problem is I have nothing to check these against except common sense.
Hi
Oh, so you want to double check your calculation in position space!
Is your L_z matrix diagonal? Then if you have the eigenstates of L_x, say, as a column vector, just reexpress that eigenstate in terms of the Y_lm and apply the differential operator expression of L_x on it as a check.
I mean, if L_z is -1,0,1 on the diagonal then it means that the column vector with 1 at the top represents Y_(l=1, m=-1), the column vector with one in the middle represents Y(l=1, m=0) etc.
Hi nrqed
Yes, Lz is diagonal. In fact, I'll struggle with LaTex and tell you the matrices:
[tex] L_{x} = \frac{\hbar}{\sqrt{2}} \left(\begin{array}{ccc}0&1&0\\1&0&1\\0&1&0\end{array}\right) [/tex]
[tex] L_{y} = \frac{\hbar}{\sqrt{2}} \left(\begin{array}{ccc}0&i&0\\-i&0&i\\0&-i&0\end{array}\right) [/tex]
[tex] L_{z} = \hbar \left(\begin{array}{ccc}1&0&0\\0&0&0\\0&0&-1\end{array}\right) [/tex]
This gives my eigenvectors for Lx as:
[tex] \frac{1}{2} \left(\begin{array}{c}1&\sqrt{2}&1\end{array}\right) \frac{1}{\sqrt{2}} \left(\begin{array}{c}1&0&-1\end{array}\right) \frac{1}{2} \left(\begin{array}{c}1&-\sqrt{2}&1\end{array}\right) [/tex]
So if I get this right, the first eigenstate on the left corresponds to:
[tex] \frac{1}{2} Y_{11} + \sqrt{2} Y_{10} + \frac{1}{2} Y_{1,-1} [/tex].
Is that right?
Cheers,
El Hombre
Hi nrqed
Is that right?
Cheers,
El Hombre
You are riht except for one tiny mistake: the coefficient of the Y_10 is [itex] \frac{1}{\sqrt{2}} [/itex], not sqrt(2) .
Now, if you apply L_x written as a differential operator on that expression (that will be long!) you should find that it's an eigenstate with the expected eigenvalue. But if you want to just make one double check, you should use the second eigenstate of L_x which at least has no Y_10 term!
It's long to check this way but that's the way to do it if you really don't mind all the algebra. The fact that you got the correct eigenvalues for the matrices L_x and L_Y is already a convincing argument that you di dit right. If you want to be sure that you got the correct corresponding eigenstates, you coudl simply apply the matrices on your answer and check that it works. That would be much quicker than using the representations as differential operators.
Hi
Yeah, that's my latexing again. If you click on it you'll see I did put a \frac in there but to no avail. I don't know why they come out like that but I just don't spend enough time on here to get to grips with the grammar.
Cheers. Yes, that does seem overcomplicated, to the point where I'm wondering if it can possibly have been what was intended. But even if it isn't I am at least wiser now. Just not about latex.
Thanks again for all your help.
El Hombre
What are eigenvalues of L operators?
Eigenvalues of L operators are the values that satisfy the equation Lψ = λψ, where L is a linear operator and ψ is the corresponding eigenvector. The eigenvalues represent the possible outcomes of a measurement of the observable associated with the operator L.
What is the significance of eigenvalues of L operators?
Eigenvalues of L operators are significant because they provide information about the quantum state of a system and the possible outcomes of measurements. They also allow for the calculation of expectation values and probabilities in quantum mechanics.
How do you calculate eigenvalues of L operators?
The eigenvalues of L operators can be calculated by solving the characteristic equation det(L - λI) = 0, where I is the identity matrix. This will give a set of possible eigenvalues, which can then be substituted into the original equation Lψ = λψ to find the corresponding eigenvectors.
What is the relationship between eigenvalues and eigenvectors of L operators?
Eigenvalues and eigenvectors of L operators are related in that each eigenvalue corresponds to a specific eigenvector. The eigenvalue represents the "size" of the eigenvector in the direction of the operator L. Additionally, eigenvectors with different eigenvalues are orthogonal to each other.
How are eigenvalues of L operators used in quantum mechanics?
Eigenvalues of L operators play a crucial role in quantum mechanics as they allow for the calculation of expectation values, probabilities, and other important quantities. They also provide a way to describe the quantum state of a system and understand the possible outcomes of measurements.
