Eigenvectors and diagnolization
  • Thread starter Thread starter Hallingrad
    Eigenvectors
Hallingrad
Two questions. First, I'm given a 3x3 matrix with the last row all zeroes. I'm asked to diagonalizable it, but the determinant is 0, so there are no eigenvalues. Am I reasoning correctly here? It seems an odd question to ask.
Second, I'm asked to prove that if A n x n matrix in C space, then if A has n distinct eigenvalues, A is then diagonalizable. The way I proved it is to say that for A to be diagonalizable, it must have n distinct eigenvectors, which is only the case if it has n distinct eigenvalues. This seems far too easy, am I missing something?
If the determinant is 0 then 0 is an eigenvalue for the matrix
Pretty much nothing you have said is right. First of all, you are going the "wrong way". You were asked to prove that if A has n distinct eigenvalues, then it is diagonalizable.
What you are trying to prove is that "if A is diagonalizable then it has n distinct eigenvalues".
You cannot prove that because it is NOT true! Further, it is not true that a matirix having n distinct eigenvectors "is only the case if it has n distinct eigenvalues. The n by n identity matrix has n independent eigenvectors but all n of its eigenvalues is the same.
The other way is correct. Since eigenvectors corresponding to distinct eigenvalues are independent, if an n by n matrix has n distinct eigenvalues then it must have n independent ("distinct" is not enough) eigenvectors and so is diagonalizable. (Write the linear transformation corresponding in a basis consisting of those eigenvectors.)
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
