Did Einstein Truly Explain the Mystery Behind Gravity's Nature?
  • Thread starter Thread starter T.O.E Dream
    Gravity
Einstein's theory of gravity revolutionized the understanding of the phenomenon by describing it as the warping of space and time, a concept that Newton's universal law of gravity did not address. However, Einstein's explanation raises further questions about why mass causes this warping, a query that remains largely unanswered in science. This pattern of advancing theories answering previous questions while leaving new ones unresolved is common in scientific progress. Historical examples illustrate how new discoveries, like Joule's work on energy conservation, led to deeper inquiries that shaped future theories. Ultimately, the nature of fundamental science often leads to the conclusion that some questions, particularly "why," may be inherently unanswerable.
T.O.E Dream
Before Einstein, Newton had explained how gravity works (universal gravity law,,,) but he didn't explain what it actually is. Then came Einstein and proclaimed that gravity is the warping of space and time meaning he had explained what it actually is. But did he really explain why it is the way it is. In other words he explained gravity is mass warping space and time but did he explain exactly why mass warps it?
Questions in science that ask "why" are generally difficult or impossible to answer. In addition to questions about gravity, one can ask similar questions about the speed of light or the size of Planck's constant.
It's always this way in science: each newly accepted fundamental theory answers questions that preceding theories could not answer, but yet the new theory itself is limited and there will (always) be questions that it does not answer.
Example 1: Around 1850 James Joule empirically demonstrated the conservation of energy between work and thermal energy ('heat'). In those days a major practical problem with drilling was the amount of thermal energy ('heat') generated by the drill, and believe it or not this was not only considered unintuitive, but it was not understood by anyone until Joule. To see this, note that the way thermal energy ('heat') flows between objects of different temperatures can be (and was) conceived as the flow of a fluid. The heat equation and the diffusion equation are one and the same.
Anyway, in this framework the question remains "Why is work equivalent to thermal energy ('heat')?" The answer was to come in following generations who showed that thermal energy ('heat') in a macroscopic object was in fact identical with the kinetic energy of the constituent molecules. Similarly, the classical statistical mechanics of Maxwell and Boltzmann described entropy (formerly just an abstract quantity) in terms of (the logarithm of) the number of permutations of the particles in the system that leave the macroscopic observables unchanged. But these breakthroughs brought a new set of questions ('paradoxes') , some of which directly lead to the development of quantum mechanics e.g. the Plank distribution.
Example 2. More briefly, note that Maxwell unifed electric and magnetic fields but the reason for this unification was not clear until Einstein's special relativity. But I am sure many folks on these forums have thought of all kinds of questions that relativity has not answered (e.g. its postulates) !
For these reasons we can and will continue to refine our existing theories as time goes on. One problem is that mathematical refinement and improvement of existing theories does not interest anyone other than theorists unless you can predict new phenomena that can be observed, and fundamental particle physics is presently in a phase where only a handful f < 5 of new surprising experimental facts have appeared in over 30 years!
Why is always a meaningless question in fundamental science. Things just are. There is no why.
I think it's easist first to watch a short vidio clip I find these videos very relaxing to watch .. I got to thinking is this being done in the most efficient way? The sand has to be suspended in the water to move it to the outlet ... The faster the water , the more turbulance and the sand stays suspended, so it seems to me the rule of thumb is the hose be aimed towards the outlet at all times .. Many times the workers hit the sand directly which will greatly reduce the water...
comparing a flat solar panel of area 2π r² and a hemisphere of the same area, the hemispherical solar panel would only occupy the area π r² of while the flat panel would occupy an entire 2π r² of land. wouldn't the hemispherical version have the same area of panel exposed to the sun, occupy less land space and can therefore increase the number of panels one land can have fitted? this would increase the power output proportionally as well. when I searched it up I wasn't satisfied with...
