Elastic Collision and speed of a ball
In a perfectly elastic collision involving a 120 g ball moving at 4.5 m/s and a 420 g ball at 1.2 m/s, the conservation of momentum and kinetic energy principles apply. The initial calculations for the final velocity of the 420 g ball were incorrect, leading to confusion. The correct approach to find the final velocities involves using the derived formulas for elastic collisions, which account for both momentum and relative velocity. The participant successfully calculated the final velocity of the 120 g ball as 0.63 m/s but struggled with the subsequent calculations for the 420 g ball. Clarification on the correct application of equations for elastic collisions is essential for resolving the problem.
Atlos
A 120 g ball moving to the right at 4.5 m/s catches up and collides with a 420 g ball that is moving to the right at 1.2 m/s.
If the collision is perfectly elastic, what is the speed of the 420 g ball after the collision?
m_1v_{1i}+}m_2v_{2i} = m_1v_{1f}+m_2v_{2f}
I manipulated the formula a little bit to solve for V2_f and came up with this:
(m_1v_{1i}+}m_2v_{2i} - m_1v_{1f}) / m_2
then I plugged in my numbers:
(.12*4.5 + .42*1.2 - .12*.63) / .42
simplified to this:
(.54 + .504 - .0756) / .42
and got 2.3057. Mastering physics said that is wrong however and I'm not sure what I'm doing wrong. Is the conservation of momentum the correct equation for this problem? I found the velocity of the 120 gram ball fine, which was .63 m/s, but am stuck on this one. Any help would be appreciated.
Hi Atlos, welcome to PF.
How did you get v1f = 0.63 m/s?
I came to find v1f by using the following equation:
[(m_1-m_2) / (m_1+m_2) ]v_{1i} + [2m_2 / (m_1+m_2]v_{2i}
A useful fact for straight line elastic collision is that
v_2b - v_1b = - (v_2a - v_1a)
v_1a = velocity of m1 before collision
v_1b = velocity of m1 after collision etc.
Relative velocity before the collision is the same as after, just opposite in sign.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
