Elastic Problem. Aluminum Wire in Horizontal Circle
The discussion revolves around calculating the angular velocity required for an aluminum wire supporting a 1.20-kg object to produce a strain of 1.00 × 10–3. The user correctly applies Young's Modulus to derive the force needed for the specified strain and calculates the cross-sectional area of the wire. Initial calculations yield an angular velocity of 6.27 rad/s, but upon review, a mistake is identified in the centripetal force equation. The corrected formula results in a new angular velocity of 4.86 rad/s. The user seeks confirmation on the accuracy of their revised calculations.
XwyhyX
An aluminum wire is 0.850 m long and has a circular cross section of diameter 0.780 mm. Fixed at the top end, the wire supports a 1.20-kg object that swings in a horizontal circle. Determine the angular velocity required to produce a strain of 1.00  10–3.
Y of Aluminum = 7.0x1010
Y = \frac{Stress}{strain}
Stress = \frac{F}{A}
Fc = ω2R
I use Young's Modulus with the definition of stress and I get the equation
Y = \frac{F/A}{Strain}
Then I can solve for F
A = \frac{∏(0.780)<sup>2</sup>}{4} = 4.77x10-7
F = Y x Strain x Area
Okay, now I have the force which will give me the strain that is needed. I'll apply it in an object rotating in a horizontal circle, The force that I used will be the one on the X axis. So
Fc = Fsinθ
and also
R = Lsinθ
Using the equation of Centripetal Force I get the equation for angular Velocity
ω = \sqrt{\frac{Tsinθ}{Lsinθ}}
Finally I get the value of 6.27 rad/s
I just want to know if I did it right. Because I don't have the correct answer for this. Thanks :D
Oops. What a simple mistake :|
So
ω = sqrt(Fsinθ/mLsinθ)
giving an answer of 4.86 rad/s?
