The discussion revolves around the concept of electrical potential in batteries, specifically addressing why there is no current flow between the positive terminal of one battery and the negative terminal of another when they are not part of a complete circuit. Participants explore the nature of voltage, potential difference, and the conditions necessary for current to flow in electrical circuits.
- Exploratory
- Technical explanation
- Debate/contested
- One participant expresses confusion about why there is no electrical potential between the terminals of two separate batteries, questioning the nature of the charge differential.
- Another participant explains that voltage is relative and that voltages from unconnected circuits have no relationship unless a common ground is established.
- A different viewpoint suggests that there can be a potential difference between the terminals, but measuring it is complicated due to the characteristics of voltmeters and external conditions.
- One participant proposes an analogy of splitting a battery into two monopoles, suggesting that a brief current might flow if a wire connects them, but it would stop once charges equalize.
- Another participant emphasizes the necessity of a complete circuit for current to flow, citing examples of high electric fields that can cause current across gaps.
- Discussion includes the idea that batteries do not store charge in the traditional sense but rather create electromotive force, and that without a closed circuit, current will not flow.
- One participant clarifies that connecting the terminals of two batteries effectively creates a larger battery, increasing the potential difference across the open terminals.
- Another participant notes that there is no absolute potential associated with a battery; potential is only meaningful relative to its terminals.
- Questions arise regarding the definition of terminal potential difference and its relevance in measuring electrical potential in circuits.
Participants express differing views on the nature of electrical potential and current flow between batteries, with no consensus reached on the initial question regarding the lack of current flow between the terminals of separate batteries.
The discussion highlights the complexities of measuring potential differences and the conditions required for current flow, including the importance of circuit completeness and the relative nature of voltage.
