Electric Dipole / Air Ionization
The discussion centers on an electrodynamics question regarding the sensation of a spark when touching another person, specifically whether the cause is an excess of protons or electrons. The game show "1 vs 100" identified the correct answer as electrons, while the user argues for protons based on the concept of electric dipoles and charge distribution. However, the counterargument highlights that protons cannot exist freely in normal conditions and that the spark is a result of current flow, which involves electrons. The conversation suggests that the shock experienced is likely due to electron ionization with air molecules, supporting the show's answer. Overall, the debate emphasizes the complexities of electric charge interactions and the nature of sparks.
kellenhockey6
I have an electrodynamics question stemming from a recent episode of the game show "1 vs 100" in which I disagreed with the show's answer.
The question is: "You touch your grandma's elbow and feel a spark. What do you have an excess build-up of, besides shame?"
Answer choices were: A-protons, B-neutrons, C-electrons.
The correct answer, according to the show is C, electrons.
I however feel A, protons, is a more appropriate answer. If you consider an electric dipole, with equal and opposite charges q+ and q-, then their electric dipole moment, a vector quantity, is commonly defined as the product of the charge q and distance, d, between the two charges pointing in the direction of the positive charge. This would suggest the electric field lines point towards the positive charge, in this case excess protons. The only flaw I can see in this logic is what creates the actual "shock." I am assuming the shock occurs at the positive charge. (Although, from personal experience I recall both people receiving a shock, which complicates the question as either A or C could be correct.)
Could this possibly be the fault in my logic? Perhaps the shock is actually the result of the electrons ionization with the air molecules.. which would explain answer C...
Thanks for any insight, explanation or debate.
-Jordan
In normal condition, how can you have a free proton? Electron, proton, neutron exist in our body in the form of molecular. Therefore, I think the only dipole we may have is induced dipole, which is created only by outer field.
Moreover, spark is something like current, and current is the flow of electric charge (electron or hole). In this case, hole can't be an answer.
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
