Electric field = 0 at what point on x axis?
15 replies · 3K views
connor02
you have a +3C and a -1C charge on the x axis. the +3C charge is at the origin and the -1C is at x=1. At what point on the positive x-axis does E=0?
E=kQ/r^2
So i have
E=(-1k/r^2)+(3k/(1+r)^2)
Setting E=0
1k/r^2=3k/(1+r)^2
r= sqrt(0.5) = 0.707
is this correct?
Will your answer be a point in between the two charges, or to the right of each of them?
connor02 said:
So i have
What does "r" mean?
connor02 said:
Setting E=0
1k/r^2=3k/(1+r)^2
is this correct?
No, r= sqrt(0.5) is not correct. How did you get it?
ehild
r=the point on the x-axis where the E firld is 0
right?
You used the expression of the electric field at distance "r" from a point charge. "r" is distance, not a point. What do you substitute for "r" for the 3C and -1C charges? ehild
my bad. r=distance to the right of the -1C charge. x=1.707 is the point on the x-axis where E=0.
right?
right?
No, it isn't. Your r is clearly a number, not a point. I suspect you mean it is the x-coordinate of such a point. In that case, the distance to 0 is r but the distance to 1 is |1- r| not 1+ r.
right?
If so, your equation 1k/r^2=3k/(1+r)^2 is correct, but the solution is wrong. Check it.
ehild
WOW i feel STUPID.
r=-0.366 or 1.366
Since x is to the right of the -1C charge, x = 2.366 when E=0.
I hope i am right now.
Thanks man!
Now, I'm just curious, but if I wanted to find the spot where V=0, I would have
0=3Q/(1+r) + (-Q/r)
so r=1/2
Does that mean V=0 at x=1.5 or V=0 at both x=1.5 and x=0.5?
I think it is the second one as all potential lines have to form a closed surface.
Am I right?
thank you.
It is less confusing if you calculate with the position of the point on the x axis, that is with its x coordinate.
If a point charge Q is at position x=a, its contribution to the potential at x is kQ/|x-a|. Note the absolute value in the denominator!
In this problem, U(x)=3k/|x|-k/|x-1|. U(x)=0 at x=1.5 and x=3/4.
ehild
Yes you are right, it is a lot easier to make sense of the answer if i use the point on the x axis.
Why did you use absolute value?
I used
0 = 3k/x + [(-Q)/(x-1)]
and i get the solution x = 1.5 only
thanks.
The term "r" in the denominator of the potential is distance. The distance is positive (or zero). The coordinate can be both positive and negative.
At distance r from a point charge, the potential is the same either at the right hand side of the charge or at the left hand side.
Find the potential of the -1 C charge at x=3/4. What do you get without absolute value and what is the right value of the potential?
ehild
