Electric field and potential at the origin
5 replies · 2K views · last reply
cdummie
I have to find a electric field vector and a potential of the point in the origin of the x0y coordinate system (0,0) due to a longitudinal charge placed on a half circle as shown in the picture, with radius a.
Coulombs law.
Diagram of x and y axes crossing at the origin, with a semicircle of radius a drawn below the x-axis and a radius line labelled a from the origin to the arc.
Using Coulombs law:
Equation for the differential electric field: dE vector equals dQ divided by 4 pi epsilon zero times r squared, multiplied by the unit vector r0 vector.
Vector E has two components:
Two equations: dE_x = dE cos θ = 0 labeled symmetry, and dE_y = dE sin θ.
Which means E=Ey.
Since dQ=Q'dl=Q'adθ
Handwritten derivation of the y-component of electric field at the origin: Ey equals the integral of dE sin theta, evaluating to -Q'/(2 pi epsilon0 a) after integrating over theta from pi to 2 pi.
If someone notices any mistakes up here, please point it out, since i haven't noticed any.
Now, for potential:
Equation: V = integral of E-vector dot dl from a to infinity, equal to the integral from a to infinity of -Q' divided by (2 pi epsilon-0 a), dy.
dl=dy because E has only y component, now when i integrate this i have V=∞, which seems wrong to me, so if someone knows how to solve this please post solution here.
Why do you integrate from a to infinity?
Also, E will depend on y. There is an easier way to calculate the potential, without electric fields.
Well i thought, since distance from point whose potential i want to know and charge is a i put first limit a, and since reference point is at infinity (i think i haven't pointed that out in the statement). I think i know what do you mean by easier way its probably dV=dQ/4πξ0a and then since dQ=Q'dl when i integrate it i get V=Q'/4ξ0. Is this correct? If it is then i should get the same thing doing it the way i did up there, but obviously i won't get the same thing as here.
Yes that is correct.
The approach with the electric field would need a path from the reference point to the position where you want to know the potential. And you would have to calculate the electric field everywhere along this path. The second part is quite messy.
That means that second approach is better for finding potential (i mean it's easier), I've done it that that way, but i thought if i solve it using electric field it could confirm that i did it correctly since the second approach seemed simple and i thought, if it's that simple, then probably i did something wrong. Anyway, thank you for help. :)
Solving it via electric fields is much more work. It would be a cross-check, but too tricky for such a homework problem.
