Electric field between a needle and a plate
The discussion revolves around calculating the electric field between a needle and a metal plate when a high voltage is applied. Participants explore the theoretical aspects of electric field distribution and density, particularly in relation to a dielectric material on the plate's surface.
  • One participant presents a formula for the electric field, questioning its validity and dimensionality.
  • Another participant expresses uncertainty about the formula's applicability and suggests that a detailed calculation is necessary for the field beneath the grounded plate.
  • A participant acknowledges the need for clarification on the formula and indicates a willingness to perform calculations based on guidance from others.
  • Further discussion includes a refined equation for the electric field, with a suggestion that the radial distance should be defined more clearly.
  • One participant proposes viewing the configuration as a point charge opposite a grounded plate, referencing existing literature for potential solutions.
  • Another participant clarifies their focus on the electric field effects on a liquid dielectric on the plate's surface, indicating a simplification by treating the pin as a point charge.
Participants express disagreement regarding the validity of the initial formula and its dimensionality. There is no consensus on the correct approach to calculate the electric field, and multiple competing views remain regarding the methods to be used.
Participants note limitations in the definitions and assumptions surrounding the formula, as well as the complexity of calculating the electric field in the specified configuration.
Mniazi
http://i66.tinypic.com/2yts08m.jpg
I was doing an experiment in which i have a needle perpendicular to a metal plate. I run 210kV between them. I want to find out the electric field between the two, and I also want to know the electric al field density through the metal plate? Pls help. I found a formula for the electrical field. it was $$E(r) = \frac{V*a}{r}*\frac{1}{1-a/b}$$
where V is the applied voltage, a is the radius of the pin point, b is the distance from the pin point to the grounded plate, and r is the radial distance from the pin point to the grounded plate?
The plate is a circular piece of metal, I want to find the density of the electrical field going through a smaller circular region right below the metal. will I need to put r as the radius of the area?
You sure about this expression ? It doesn't even have the right dimension !
Where does this formula apply ? Is it an approximation in a limited region ?
For the field underneath the grounded plate a very detailed calculation will be necessary.
No I am not sure about this equation. I got it on a website (http://www.afssociety.org/air-filtration/81-what-is-an-electret ) It says it is the electric field distribution from the pin to the plate. If detailed calculation is necessary then can you like guide me on it? I will perfomr the calculations and then update over here.
Well, at least that settles the dimensionality:$$E(r) = \frac{V*a}{r^2}*\frac{1}{1-a/b}$$
and it looks like the electric field from a point charge ##\ \ \displaystyle q = {4\pi\epsilon_0 V_0 \over {1\over a} - {1\over b} }##
It is unfortunate that they don't clearly define ##r## but I suspect it is the radial distance to the center inside the tip (the center of the sphere with radius a). So surfaces with the same |E| would then be spherical shells and that should work reasonably well if ##b \gg a##. For the region between tip and plate. The further sideways, the worse. And not sensible upwards along the rod at all.
Another way to look at this configuration is to consider it as a point charge opposite a grounded plate, for which there is plenty info (see e.g. Errede 2007). You get a dipole field and the surface charge on the plate can easily be determined.
But you are looking for trouble: you want the field underneath a finite circular grounded disc. As Errede says on his page 14, you don't get a solution for the region where the image charge is located.
So all I can think of is a numerical approach. No experience. Perhaps https://www.integratedsoft.com/papers/techdocs/tech_1cx.pdf helps ?
Forgive my typo in the equation i wrote.
Well I am not trying to find the field under the plate. I am actually studying effects of the electric field on a liquid dielectric on the surface of the plate. So I wanted to find the field in that area of dielectric on the plate. I think taking the pin as a point will simplify stuff, so ill go with that. Ill check out the links you gave as well.
  • · Replies 16 ·
  • · Replies 18 ·
