Electric field inside conductor
An electric field exists inside a conductor when a battery is connected to a loop of wire with resistance, leading to a non-zero electric field represented by E = J/sigma, where sigma is conductivity. This phenomenon occurs because the condition of electrostatic equilibrium, which states that the electric field inside a conductor is zero, only applies when there are no moving charges. In dynamic situations where fields are applied, charges move, and thus the electric field can be present. The discussion references Griffiths' electrodynamics to clarify this distinction. Understanding this difference is crucial for comprehending how electric fields operate in conductive materials under various conditions.
f2009049
When we connect a battery across a loop of wire having some finite resistance there comes into picture an electric field E which is empirically given by J/sigma.(sigma==>conductivity).
but how can there exist an electric field inside a conductor??We had already learned that electric
conductor inside a conductor is zero.please explain.
(reference griffiths -- electrodynamics)
That's only true for the case of electrostatic equilibrium. When you apply fields and have moving charges, that statement no longer applies.
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
