Electric field is zero at center of cavity?
The discussion centers on whether an electric field exists at the center of a cavity within a sphere, specifically in relation to Gauss's law. While Gauss's law can be applied, it indicates that the electric flux through a closed surface is zero if no charge is enclosed, but does not directly imply that the electric field itself is zero. To determine the electric field, one must consider additional factors such as the symmetries of the field and the Gaussian surface used. The conclusion is that while zero enclosed charge suggests a zero electric field at the center, this must be substantiated through further reasoning involving symmetry and multiple Gaussian surfaces. Understanding these nuances is crucial for accurate application of Gauss's law in this context.
positron
Does an electric field exist in the center of a cavity inside a sphere? Can I just apply Gauss's law and say that because no charge is enclosed, the electric field is zero? If not, why can Gauss's law not be applied?
Thanks,
positron
Gauss' law can be applied ; but it doesn't say that the E-field is 0, it only says that the flux of the E-field through a closed surface must be 0. So as long as one part is "incoming" and another part is "outgoing" then that's still ok.
cheers,
Patrick.
Gauss' Law only tells you about the flux of the electric field vectors on that Gaussian surface... You need to appeal to additional information, e.g. symmetries of the field and/or of the Gaussian surface, to deduce information about the field vectors themselves (i.e., derive an expression for E on that surface). In other words, for your problem, you have to argue [say, using Gauss and symmetry... and possibly a sequence of Gaussian surfaces] that zero enclosed charge implies zero electric field at the center.
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
