Is the Electric Field of a Dipole Reversed on the Negative Z-Axis?
issacnewton
Hi
I have a question about the electric field of a dipole located at the origin. We know that the
coordinate free form for the electric field of a dipole is
\vec{\mathbf{E}}=\frac{1}{4\pi \epsilon_o}\frac{1}{r^3}\left[\frac{3(\vec{p}\cdot \vec{r})\vec{r}}{r^2}-\vec{p}\right]
Now let
\vec{r}= x\hat{\mathbf{x}}+y\hat{\mathbf{y}}+z\hat{\mathbf{z}}
be the vector of some point in space. Assume that \vec{p}=p(\hat{\mathbf{z}}).
So
\vec{p}\cdot \vec{r} = zp
so plugging everything we get for the electric field,
\vec{\mathbf{E}}=\frac{p}{4\pi \epsilon_o}\left[\frac{3z(x\hat{\mathbf{x}}+y\hat{\mathbf{y}}+z\hat{\mathbf{z}})-(x^2+y^2+z^2)\hat{\mathbf{z}}}{(x^2+y^2+z^2)^{5/2}}\right]
Now, if I want to get the electric field on the negative z axis, then I put x=y=0 and
z= -r , so I get
\vec{\mathbf{E}}=\frac{2p(-r)^2 \hat{\mathbf{z}}}{4\pi \epsilon_o(-r)^5}
which is after evaluating the brackets,
\vec{\mathbf{E}}=-\frac{2p \hat{\mathbf{z}}}{4\pi \epsilon_o r^3}
which points in the negative z direction, but if we look at the original formula for the
coordinate form of the electric field and then evaluate the electric field on the negative
z axis, it points toward the positive z direction. So what's happening here ?
thanks
Your fallacy lies in evaluating the denominator. Note the following
\left(x^2\right)^{1/2} = |x|
and NOT x. That fixes your problem.
thanks prahar
how could i miss that ? :-p
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
