Electric field of electric current
Electric current generates both an electric field and a magnetic field at a stationary point due to the movement of charges. While all charges produce an electric field, the magnetic field observed is a result of the electric field created by these moving charges. The relationship between electricity and magnetism is unified under electromagnetism, where perspectives of motion affect the observed fields. A stationary observer relative to the current wire perceives a magnetic field, while an observer moving with the charge sees an electrostatic field. Understanding this concept is essential for solid-state physics and can be grasped through foundational studies in electromagnetism and relativity.
hokhani
Does electric current also produces electric field (in addition to magnetic field) at a typical stationary point? In other words, electric current includes the moving charges. Do these charges produce electric field at a stationary point? Or, does the electric field of these charges come into the form of the magnetic field observed at this point?
All charges produce an electric field.
The magnetic field is the effect of an electric field due to moving charges.
You've seen the special relativity explanation of magnetism?
Likes hokhani
Thanks. I haven't seen the special relativity explanation of magnetism. Do you mean that one who is moving with charge, sees the electric field of charges at the stationary point while one who is resting at the stationary point, sees that field as a magnetic field?
That's the idea ... but since there is no such thing as a "stationary point", we have to say an observer who is stationary wrt the wire carrying a current see's the B field of the current while the one stationary wrt the current sees just an electrostatic field. Electricity and magnetism are "unified" into one electromagnetic force, with the everyday separate-seeming effects actually being mixed up together like time and space is in relativity - it's the effect of perspective.
The more complete description is that both effects are the result of an underlying phenomenon we call "electromagnetism". The whole thing is even simpler in the particle physics model. Where is your education up to right now?
I am PhD student of solid state physics and I haven't been involved in some fundamental concepts.
Oh neat - we share a field, though I have not practised for some time. Electromagnetism is fundamental to solid state, but you have more quantum theory than relativity.
You would normally cover the unification of electricity and magnetism in year 1 undergraduate work (In NZ anyways)... but the SR description may not be covered until year 2. Looks like you just need a primer ... a quickie is to find the lecture series where the subject is covered and ask the lecturer for the notes (and/or sit-in on the lectures). There's a bunch of different ways to catch up depending on where your maths is: it may be worthwhile to start with covarient formulism of Maxwell's equations and GR in flat spacetime than go back to undergrad step-by-step. OR just think in terms of field theory.
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
