Electric Field over a charged cylinder using only Coulomb's Law
The electric field at a point on the central axis of a solid, uniformly charged cylinder can be calculated using Coulomb's Law and involves a triple integral setup. The integral derived is \bar{E}_{z}=\frac{2\pi\rho}{4\pi\epsilon_{0}}\int^{h/2}_{-h/2}[1-\frac{z'-z}{\sqrt{(z'-z)^{2}+R^{2}}}]dz. A common mistake arises from incorrectly assuming that \frac{z'-z}{\sqrt{(z'-z)^2}} = 1, which leads to complications in the integration process. The resulting expression includes logarithmic terms that do not simplify to zero when evaluated at z' = 0.
  • Understanding of Coulomb's Law
  • Familiarity with triple integrals in calculus
  • Knowledge of electric field concepts
  • Experience with logarithmic functions and their properties
  • Review the derivation of electric fields using Coulomb's Law
  • Study the properties of integrals involving absolute values
  • Learn about the implications of symmetry in electric fields
  • Explore advanced integration techniques for complex functions
Students studying electromagnetism, physics educators, and anyone involved in solving problems related to electric fields and charged objects.
PeteyCoco
What is the electric field at a point on the central axis of a solid, uniformly charged cylinder of radis R and length h?
Well, I've set up the triple integral and have gotten to this point:
\bar{E}_{z}=\frac{2\pi\rho}{4\pi\epsilon_{0}}\int^{h/2}_{-h/2}[1-\frac{z'-z}{\sqrt{(z'-z)^{2}+R^{2}}}]dz , z' is the location of the test point
When I integrate this I get a constant term and a mess of logarithms. I know that the field should be 0 when z' = 0, but it doesn't check out. What's wrong?
Re-evaluate how you got the 1 inside the brackets in the expression above. I suspect that you got this from assuming that ##\frac{z'-z}{\sqrt{(z'-z)^2}} = 1##. But, recall that ##\sqrt{x^2} = |x|##.
Alright. Now that I've changed that term, it vanishes when integrated, but the second term in the integrand still turns into
\frac{1}{2}ln| (z'-z) + \sqrt{(z'-z)^{2}+R^{2}} |^{h/2}_{-h/2}
Which, as far as I can tell, can't be reduced to 0 when z' = 0
Nevermind, integrating this absolute value function is a bit more work than I thought it was.
Also, I don't see how you are getting a logarithm expression in the result of the integration.
  • · Replies 16 ·
  • · Replies 36 ·
  • · Replies 26 ·
