Electric Field -- Potential between the ends of a 2 meter stick
The discussion revolves around determining the electric field magnitude based on the potential difference between the ends of a 2 meter stick in a uniform electric field context. The original poster attempts to apply formulas related to electric potential and electric fields but expresses uncertainty in their application.
  • Participants explore the relationship between electric potential and electric field, questioning the relevance of point charge formulas in the context of a uniform electric field. There is a focus on understanding the variable representing distance in the formulas and its implications.
The discussion is active, with participants providing hints and guidance on the nature of electric fields and potential. There is an exploration of the differences between uniform and point charge fields, and suggestions for reviewing relevant formulas have been made.
Participants are navigating the complexities of electric field concepts and the specific conditions of the problem, including the uniformity of the electric field and the potential difference provided.
Fikremariam
The potential difference between the ends of a 2 meter stick that is parallel to a uniform electric field is 300V determine the magnitude of the electric field
E=F/q
E=K q/r square
I tried to find the charge from the formula v=k q/r and apply it to find the field but couldn't be sure
Fikremariam said:
Homework Statement:: The potential difference between the ends of a 2 meter stick that is parallel to a uniform electric field is 300V determine the magnitude of the electric field
Relevant Equations:: E=F/q
E=K q/r square
In the formulas, ##E = kq/r^2## and ##V=kq/r##, what does the variable ##r## represent? Be specific.
It represents the distance from the charge
More specifically, the distance from a point charge. In this problem, you're told there's a uniform field—that is constant magnitude and constant direction. Is the field of a point charge uniform?
I didn't know that is why I asked
But you can figure it out. Look at the formula for ##E##. If you plug in different values for ##r##, you don't get the same number, i.e., the magnitude changes with distance, so the field of a point charge isn't uniform. That means the formulas that apply to a point charge probably aren't useful for this problem.
I'm guessing you feel a bit overwhelmed by the many formulas for the electric field, potential energy, electric potential that you've encountered recently. It might be a good idea to write them all down on a piece of paper and note when each formula is applicable. I suggest this for two reasons: (1) when you do this, you'll probably see there aren't as many formulas as you thought there were, so the topic will seem more manageable; and (2) it's helpful to have this sheet when you're working on homework.
In this problem, you're looking for a relationship between ##\Delta V## and ##E## when ##\vec E## is uniform. Try checking the chapter summary for such a relationship.
Here's a hint: What are the SI units of the electric field?
  • · Replies 16 ·
  • · Replies 22 ·
