Electric Field Calculation for Infinitely Long Charged Line and Rod
The discussion focuses on calculating the electrical force exerted on a straight rod by an infinitely long charged line using Gauss's Law. The linear charge density of the line is denoted as λ1, while the rod has a varying charge density described by λ(rod) = (λ2*b)/(y+a). The initial attempt at a solution yielded an electric field expression E = (λ2 * b) / [2pi*ε0*(a+b)^2], which was identified as incorrect due to its independence from λ1. The correct approach involves integrating the force on infinitesimal segments of the rod, accounting for their distance from the charged line.
  • Understanding of Gauss's Law
  • Familiarity with electric field concepts
  • Knowledge of linear charge density
  • Basic calculus for integration
  • Study the application of Gauss's Law in electrostatics
  • Learn about electric field calculations for continuous charge distributions
  • Explore integration techniques for calculating forces in physics
  • Investigate the effects of varying charge densities on electric fields
Students in physics, electrical engineering majors, and anyone interested in electrostatics and electric field calculations.
Govyadina
An infinitely long, uniformly charged straight line has linear charge density λ1 coul/m. A straight rod of length 'b' lies in the plane of the straight line and perpendicular to it, with its enared end at distance 'a' from the line. The charge density on the rod varies with distance 'y', measured from the lower end, according to λ(on rod) = (λ2*b)/(y+a), where λ2 is a constant. Find the electrical force exerted on the rod by the charge on the infinite straight line, in the λ1, λ2, a, and b, and constants like ε0.
Gauss's Law.
I first treated the problem as if there was only a point P above the infinite line and applied Gauss's Law using a cylinder as my Gaussian surface. My answer was
From my understanding, I now have to relate my first answer to a change in distance of the point P along the rod. Any help would be appreciated.
Thank you in advance.
I hope I understood your problem correct!
It's correct to use Gauss law to find the field of the line, but I think that you made a mistake because your answer is independent of \displaystyle{\lambda _1}. Also your answer is not general, because point P is not a random point, it is rod's upper end (its distance from the line is \displaystyle{a+b}).
Now let's see a way to solve the problem.
Firstly use Gauss law to find the field \displaystyle{E(r)} of the line at a random point which distance from the line is a variable \displaystyle{r}. This \displaystyle{r} must be the radius of your Gaussian cylinder.
Then take an infinitesimally small part of the rod, with length \displaystyle{dy}, which distance from the lower end of the rod is \displaystyle{y} (and consequently from the line is \displaystyle{r=y+a}). This part is charged with charge \displaystyle{dq}, so using \displaystyle{E(r)} we can compute the force \displaystyle{dF} exerted on it. Note that you can also find \displaystyle{dq} in terms of \displaystyle{y} and \displaystyle{dy} using rod's charge density.
Finally you get an equation for \displaystyle{dF} in terms of \displaystyle{y}, \displaystyle{dy} and some constants. You can integrate this equation to find the total force on the rod.
I didn't use vectors for the field or the force because I think that the direction is trivial at this problem (everything upwards).
The charge of the infinitesimally small part of the rod with length dy is λ(rod)*dy. Which is the force that acts on it? since you have found the electrical field that the line produces, then the force that exerts on a charge which lies in distance s from it is: dF = E(s)*dq.
