Electric fields, particles and deflection
3 replies · 4K views · last reply
Mr.somebody
Explain the circumstances that enable a particle to move un-deflected with uniform motion through an electric field if it is given an initial velocity perpendicular to the electric field. Assume the electric field is the only field present.[/B]
If the electric field was extremely weak and the particle had an extremely low charge.
Can you think of a property that the particle might have (or not have) that would allow it to move undeflected (even in a strong electric field)?
[EDIT: I think you're pretty close when you said "the particle had an extremely low charge". Why not go all the way? :woot:]
I don't know how I missed that THANKS! it should be neutral right?
Mr.somebody said:
... it should be neutral right?
Yes, that would be one reason the particle doesn't deflect.
Now, the original statement of the problem asks for "circumstances". But I can't think of anything else. (I don't think mental telepathy telekinesis would be an acceptable answer.)
