What Does Ground Really Mean in Electrical Terms?
In summary, the ground is taken to be the reference point for electrical circuits and has a constant voltage of zero. The Earth is a good ground and any electrical systems are physically connected to it. However, being in contact with the ground does not guarantee safety from electric shock, as the main factor is the potential difference between you and the source of electricity. Insulating materials can help reduce the risk of shock, but there will always be a potential difference between different objects and surfaces, making it impossible to completely eliminate the risk of electric shock.
hangover
The electric potential of the ground is taken to be zero.
We will get electric shock if we complete the circuit by touching the wire and standing on the ground simutaneously.(I know the shoes cannot protect us as the resistance is too small)
But what does this "ground" really mean? Does it apply to any floors we are standing,even those on high rise buildings/those do not contain any electric wires and completely made of thick,insulating material(like plastic)?
I was wondering if there are any grounds where people standing on will never get electric shock(the lethal one)?
Why you are separating your shoes from ground!
The matter is not because its called a shoes and the ground is called ground, but the matter is in the material things are manufactured from.
If the ground was made of the same material as your shoes so you will never be shocked by an electric shock.
If you want to go through details, you have to understand what do you mean by an electric shock? and how we get an electric shock?
We get an electric shock because current is flowing in our body, and there is a potential difference between our body and the ground, also our body has a resistance say R.. by applying ohms V=R*I a current I will flow in your body which causes the electric shock.
In case of an insulating shoes, the shoes has a high resistance R'..so I=V/(R+R'), and R+R'>>>>>>>>>>big then I=0 so you will never be shocked in this case.
So yes there is grounds where people can stand on and will never get an electric shock!
A ground is taken as a neutral resevoir of infinite charge. One of the effects of this is that the ground always maintains a constant voltage reference, which we usually take to be zero by convention. So if you pull off charge from the ground or sink charge into the ground then you do not change the voltage of the ground since it has an infinite amount of charge to begin with.
With that in mind, the Earth is a good ground in most circumstances. Locally, any two points will have the same potential. This isn't true over large distances though, as was discovered when they started laying telegraph, but it's ok for local areas. So anything that has a good electrical connection with the Earth (soil) is a ground. Things can be insulated from the ground though. So a person wearing rubber soled shoes is actually partially insulated, if you were to stand on a rubber stool you would be rather insulated from the ground. If however you were standing barefoot you would have an ok connection with ground. Generally though any electrical system will physically bring up a ground connection (originally created by something as simple as a metal pipe embedded into the soil outside your house).
So your connection to ground has to do with the insulating properties of the possible paths to ground through the materials you are in contact with. Though to be shocked in general just requires you to have a potential difference, you do not need to be grounded for this to exist.
thanks. i understand, but so why not the floor of the houses be installed a good insulating material layer or just be made of insulating material(good one), so that no one will get the lethal shock?
Because the only condition for a shock to occur is that you have a potential difference. Ground is a common potential that causes a shock because it is often taken as the defacto reference potential for most circuits. However, you as a body always has some kind of potential. It could be zero if you have been bumbling about on or with the ground or grounded obects, but you can also have a potential that is non-zero. For example, if you charge up yourself by scuffing across the carpet you have built up a charge and voltage that is different from the rest of the room which discharges itself when you touch an unlucky object or victim.
So the problem is, there is always a potential difference between you, the source and something else. The source voltage always has a potential difference with respect to the return line. This could be a ground line or it could be a negative hot line. You have a voltage yourself, it could be the same as the return line, in which case the hot source line will zap you, or it could be the same as the hot source line, in which case the return line would zap you (though it may not be as extreme of a zap), or you could be different from both, in which case touching either line would be uncomfortable experience.
The main difference when being shocked when you are in contact with ground is that the ground never changes voltage. So while if you charge up and shock your cat, the discharge is slight because you can only source a small amount of charge before you and your cat are at the same potential difference. However, the ground can eat up all the electrons it wants and it will never change its voltage. So being shorted to ground means you will constantly pull a stream of current from any source that can keep sending the electrons. If you are at least isolated from ground, you can still get shocked for the reasons I stated above but it will be less severe (though I reserve comments on the lethality) because your body will build up/dissipate the charge quickly and no longer pull a current.
1. What is electric potential?
Electric potential is a measure of the electric potential energy per unit charge of an electric field. It is also known as voltage.
2. What are the units of electric potential?
The units of electric potential are volts (V) in the SI system. In other systems, it can also be measured in joules per coulomb (J/C) or newtons per coulomb (N/C).
3. How is electric potential different from electric field?
Electric potential is a scalar quantity that represents the strength of an electric field at a specific point. It is a measure of the potential energy that a charged particle would have at that point. Electric field, on the other hand, is a vector quantity that represents the direction and strength of the force that a charged particle would experience at a specific point.
4. Can electric potential be negative?
Yes, electric potential can be negative. It depends on the relative positions of the positive and negative charges in the electric field. A negative electric potential indicates that a positive charge would lose potential energy if it moved from that point to another point in the field.
5. How is electric potential calculated?
Electric potential can be calculated using the equation V = kQ/r, where V is the electric potential, k is the Coulomb's constant, Q is the magnitude of the charge creating the electric field, and r is the distance from the charge to the point where the potential is being measured. It can also be calculated by integrating the electric field over a given distance.
13K
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
