Why is there a contradiction in the signs for electrical potential equations?
The discussion addresses the perceived contradiction in electrical potential equations, specifically delta EP = -W and V = -Ed. It clarifies that electrical potential is defined for a unit positive charge, meaning the signs in equations must be carefully considered based on the charge being analyzed. When moving a proton, the work done can be positive or negative depending on the direction of movement, which aligns with the sign conventions used in the equations. The confusion arises from differing assumptions about positive and negative directions in the context of electric fields and forces. Adhering strictly to the signs in calculations resolves the apparent contradiction.
x86
We have two equations
delta EP = -W
V = -Ed
Now, to my understanding for the second equation (E = -V/d) since its a vector quantity, we need to make it have direction
Therefore, if we substitute values E = -50V / 5 m = -10 N/C
We add in the negative sign to the equation because generally:
A proton would move DOWN, therefore the negative sign represents down
But the confusion stems from the second equation
A
B
If we have a proton that moves from A to B delta EP would be negative
So -d EP = -W
Work done is positive
But if we move it from point B to A, we exert force on it and therefore work done is negative (according to the equation)
This is extremely weird for me though, because in the first equation we're assuming down is negative and up in positive (like we have been for the rest of the units we've learned)
Yet for the second equation, we assume the exact opposite! Can someone clear up my confusion?
Thanks
There is no contradiction. Electrical potential is defined for a unit Positive charge. The energy for a negative charge would have the opposite sign. To move a proton in a given situation would require equal and opposite work compared with the same operation with an electron. Put the appropriate signs in your equations and the right answer will emerge. Do it for yourself and adhere scrupulously to the signs, without jumping ahead in your mind (which it can be all too easy to do). You will find it works out. No 'verbal' explanation should benecessary.
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
