Electric potential PRoblem , dont understand
The discussion revolves around calculating the electric potential from two fixed charges, q1 = +7e and q2 = -15e, separated by 23.9 cm. The user seeks clarification on why the net electric potential is zero at a point between the charges for positive values and to the left for negative values. It is emphasized that understanding the electric potential from a single point charge is crucial before addressing the combined potential from multiple charges. The conversation suggests researching the electric potential surrounding a point charge to gain a foundational understanding. Mastering these concepts is essential for solving the given problem effectively.
th3plan
In the picture i attached, particles with charges q1 = +7e and q2 = -15e are fixed in place with a separation of d = 23.9 cm. With V = 0 at infinity, what are the finite (a) positive and (b) negative values of x (in cm) at which the net electric potential on the x-axis is zero?
I don't understand why for positive net electric potential is in the middle between them, and negative is to the left. Can someone explain this.
For each of the three regions (x < 0, 0 < x < d, x > d), write an expression that describes the net potential as a function of position.
What's the electric potential surrounding a point charge?
How would i do that, my book doesn't require us to write functions. I don't know what the electric potential surround a point charge is
By "function" I just mean a mathematical formula.
There's no point in worrying about the potential from two charges until you understand how to find the potential from one charge. Look it up!
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
