Electric Pressure on a Charged Surface due to External EF
The discussion centers on the effects of electric fields on charged surfaces, specifically addressing the role of parallel components of the electric field. It is argued that while parallel components can create shearing forces, they do not contribute to net pressure on the surface. The conversation highlights that pressure is generated by forces acting perpendicular to the surface area. Additionally, shear forces are acknowledged for their role in surface tension, but they do not exert pressure in the traditional sense. Overall, the distinction between shear forces and pressure due to normal forces is emphasized.
gracy
Why he did not consider parallel force?Will parallel component of electric field not produce electric pressure on the surface?
The parallel component can only produce/result in a shearing force ; zero net pressure. Or put another way, it is orthogonal to the direction necessary to produce movement.
Likes gracy
You mean shear force does not exert pressure?
Shear force will be responsible for surface tension, as he said in the video. Pressure will be due to the force normal to the area.
It may be shown from the equations of electromagnetism, by James Clerk Maxwell in the 1860’s, that the speed of light in the vacuum of free space is related to electric permittivity (ϵ) and magnetic permeability (μ) by the equation: c=1/√( μ ϵ ) . This value is a constant for the vacuum of free space and is independent of the motion of the observer. It was this fact, in part, that led Albert Einstein to Special Relativity.
