Electrical Conductors and Insulators, help
A balloon acquires a net charge of -0.60 nC after being rubbed with fur, indicating that electrons were added to the balloon, resulting in a negative charge. The calculation for the number of transferred electrons is correct, yielding approximately 3.75 billion electrons. The confusion about the term "1.0-g" arises from its context; it refers to a mass measurement of gold and not a variable. The negative sign in this context indicates a loss of electrons, which would affect the net charge of the gold nugget. Understanding these concepts is crucial for grasping the principles of electrical conductors and insulators.
soulembracer
A balloon, initially neutral, is rubbed with fur until it acquires a net charge of -0.60nC. (a) Assuming that only electrons are transferred, were electrons removed from the balloon or added to it? (b) how many electrons were transferred?
Net Charge = Q = -0.60 nC
Electron Charge = qe = -1.602 x 10^-19 C
*meaning the Charge in 1 Electron = qe
1 nC = 10^-9 C
(a) HELP I'm confused in problem a. My book says it is added but it doesn't have any explanation. :( I want to know when electrons are removed or added.
(b) I tried this but I'm not sure if it is correct.
- I converted nC to C for the given net charge:
Q = (-0.60 nC)(10^-9C / 1 nC) = -6 x 10^-10 C or -6 EXP -10 C
-I get the numbers of transferred electrons through this:
No. of Electrons = (Q)(1 electron/qe)
= (-6 EXP -10 C)(1 electron/-1.602 x 10^-19 C)​
*cancel C unit​
=3.75 x 10^9 electron or 3.75 EXP 9 electron
is this correct? I'm confused because my classmates' answer is different compare to me.
and by the way, this one doesn't have any relation with this problem, what does this mean:
1.0-g
what is -g? It's not a variable. It is just given as it is. It also belong in the topic of Electrical Conductors and Insulators.
Please help.
To answer a) Initially the balloon was neutral. That means the net charge was 0 C. Then, after charging it, the balloon acquired a NEGATIVE charge. That means electrons were added. Reason ? Well, electrons have negative charge. It's as simple as that
marlon
b) looks ok to me
1.0-g, can you tell me more about where you read this ? What question in your book ? What example ?
marlon
marlon said:
b) looks ok to me
marlon
thanks for explaining problem a. I didn't figure it out. :)
regarding 1.0-g:
Suppose a 1.0-g nugget of pure gold has zero net charge. What would be its net charge after it has 1.0% of its electrons removed?
In my understanding, that is in grams, but I wonder why it has negative sign..
