Electrical Engineering - circuits - Reactive Networks
In summary: Vo being the Thevenin Voltage.It looks like you are going to need to review your text or course notes for more information on how to determine the Thevenin voltage.In summary, using Thevenin's theorem, the circuit contains a single voltage source and a series impedance. To calculate the Thevenin voltage, remove the load and find the voltage at the output terminals.
Frankboyle
25
1. Homework Statement
There are multiple parts to this question, but I have only got through the first 2 before getting stuck. Please could somebody give me a hand as I am really struggling :frown:
(a) Calculate the phasor voltage of the voltage source and the phasor current of the current source in both Cartesian and Polar coordinates. Use peak values when calculating the phasors.
(b) What are the phasor voltage and impedance of the Thevenin equivalent circuit of the power supply? (Use peak values for the voltages and currents in your calculation)
(c) What are the phasor current and impedance of the Norton equivalent circuit of the power supply? (Use peak values for the voltages and currents in your calculation)
(d) At what frequency should the circuit operate for the current flowing through the load and the voltage across it to be in phase?
(e) It is known that for a different load the voltage and current across the load are 240cos(ωot+45°) V and 4cos(ωot+60°) A, respectively. How much power is dissipated in that load?
These are my attempts at part a, but I was unsure whether they're correct or not
(a)
Voltage source:
|V| = 10 V; Φ = 75°
V = 2.5882 + j 9.6593 V
Current source:
|I|=0.8 A; Φ = -30°
I=-0.4 + j 0.6928 A
Your voltage source phasor looks okay, but your Cartesian form for the current source does not. You have correctly transformed the sine function to a cosine, but the components that you calculated aren't right. It's a good idea to make a quick sketch of the phasor to confirm that your components look reasonable.
Likes gracy
Out of curiosity: is that a short-circuit I see going down from between R and V ?
I've re-calculated i(t) and for the cartesian my answer is 0.6929 -j0.4.
As for the short circuit, yes I believe that is one
That's better. So what's your next step?
Part (b) requires the circuit to be reduced using Thevenin's theorem, so the overall circuit contains just a single voltage source and a series impedance. I'm not entirely sure how to go about it however
What's the "algorithm" for determining a Thevenin equivalent?
Likes gracy
What do you mean exactly?
What is the procedure to apply to determine a Thevenin equivalent?
Likes gracy
Firstly, remove the load and create an open-circuit. This renders both the current and voltage sources as 0.
Secondly, I would draw up the remaining circuit which would only contain the remaining resistor, capacitor and inductor.
Thirdly, I would work out the impedance for each of these components. I would then combine them into one impedance for the entire circuit.
From there I am unsure what to do
I think you should review your course notes or text for a description of the procedure and worked examples.
No, that will only remove the load. The sources will still be active. You have to "manually" suppress the sources if want them suppressed. But removing the load is a correct first step.
Yes, that will yield the Thevenin impedance. But you still need to find the Thevenin voltage.
Start by creating a list of the component impedances from the given information. You should do this first thing when a problem specifies the component values and operating frequency. Then:
1. Remove the load and find the voltage at the output terminals (all sources are still active). That's your Thevenin voltage.
2. Suppress the sources: replace voltage sources with short circuits (wire), replace current sources with open circuits (remove them from the circuit). Then find the equivalent impedance of the resulting network looking into the load terminals. That's your Thevenin impedance.
Likes gracy
When calculating the Thevenin voltage, do I combine the capacitor with the inductor? Or would I use mesh analysis on each mesh?
Use whatever technique you're comfortable with. To me it looks like a simple potential divider arrangement...
Hint: Pay close attention to the effect of the short circuit that @BvU pointed out. It may make your task simpler. Can the current source affect the output voltage in any way? Where does its current flow?
Likes gracy
So, I'm planning on using the Voltage Divider Vo = V(Z2/Z1+Z2) equation, with Vo being the Thevenin Voltage.
As for the Current source with resistor in series, to work out the voltage from that, what value for the current would I use? Would it be the modulus of I from part (a)? or just the real part of the cartesian for I?
Good.
Use whatever form of the source phasor is convenient for calculation. Since you're looking for voltages at this point, you must use the compete phasor information, not just real or imaginary parts. When you start looking at power dissipation, then you will need to be more careful with the individual components of the phasor (only "real" power counts for power dissipation).
Have you determined that the current source can affect the output voltage in some way? What is the potential at the right end of the resistor with respect to the bottom rail (the common node running along the bottom of the circuit).
Likes gracy
Ok, I've used the value of the modulus of the current (0.8A) to work out the voltage from the current source and resistor in series.
That worked out to be 8000V. As the voltage source is only producing 10V this seems a little off.
Yes, but do you care at all about the voltage drop across the resistor? Where does this 8000 V potential occur in the circuit? Sketch it in on your circuit diagram. If you were to connect the negative lead of a voltmeter to the common reference node (the bottom rail), where would you place the positive lead to read this 8000 V potential?
Likes gracy
This is my circuit diagram for now. I've put the 8000V opposing that of the voltage produced by the voltage source. Is this correct? Or should it be flowing in the same direction.
What you've labeled as V1 and V2 are currents, not voltages. Voltages (potential changes) occur across components (between nodes), currents flow through wires and components.
Your 8000 V potential change occurs across the resistor R. At which end of the resistor would you read 8000 V if you were to connect a voltmeter lead to it (with the other lead connected to the assumed reference node at the bottom).
What readings would you expect at the points labeled a, b, and c?
Likes gracy
Ah of course, my mistake!
At a I would expect 8000V, but at b and c I would expect 0
Yes! :smile:
So, does that make your task simpler?
So the voltage produced by the current source and resistor in series doesn't affect the voltage produced by the voltage source
Right. The short circuit effectively divides the circuit into two independent circuits, isolated from each other.
Likes gracy
So here is the circuit when you ignore the current source+resistor. What value do I use for V though? Would I use the peak value of 10V?
You would use the phasor value (magnitude and angle). Here the voltage supply has a built-in phase angle. However...
When there's only one source involved it's possible to assume its angle to be a reference angle, and treat it as zero for all intermediate steps. When you get to the end of a current or voltage calculation you can then add that phase shift back onto the result. For now I'd suggest taking the source voltage as given, phase angle and all, if your marker is going to inspect intermediate results in your work and doesn't recognize (or appreciate) the shortcut.
When the problem statement tells you to use the peak value for the phasors I believe they are referring to peak versus rms values. Usually when a source is specified in the form Acos(ωt + Φ) the A is taken to be a peak value. Phasors on the other hand are assumed to be specified as rms values. A typical first step in an AC circuit analysis is to convert given time-domain functions for the supplies to rms phasor values. But in your problem statement you are directed to use peak values for the phasors, so you have to comply and not convert to rms magnitudes for the phasors.
So bottom line: use 10 V ∠75° for the voltage source.
Likes gracy
So by using the cartesian form of the voltage, I have gotten to the answer of:
VT= 2.5517 + j9.5233
As for ZT, I simply added Z1 and Z2 together to get the overall impedance, which was:
ZT=0+j101.429
The values look to be a bit low. Are you losing accuracy by truncating or rounding intermediate values?
ZT=0+j101.429
Check again how those impedances are connected when the source is suppressed.
Likes gracy
I used the voltage divider equation to get a value of (70/71)*V for Vo.
I then multiplied the cartesian form of V (2.5882 + j9.6593) by 70/71, which gave 2.5517 +j 9.5233
Am I mean't to use (Z1*Z2)/(Z1+Z2) to find ZT, rather than just adding them?
Can you show your voltage divider work in more detail?
Yes. Look how those components are connected to each other when the voltage supply is shorted.
Likes gracy
  • #31
Here's my working out for the voltage divider
  • #32
Okay. Note that the impedance of a capacitor is negative. 1/j becomes -j when you move it to the numerator.
Likes gracy
  • #33
[moderator note: partial solution removed --- Please do not solve the Original Posters problems for them. Hints and suggestions are fine, but they must do the work themselves.]
Does the fact the impedances only have an imaginary part make a difference when working out VT using the voltage divider? Do you still multiply both parts of the voltage by Z2/(Z1 + Z2) which is what I did, or would you multiply the real part by 0 making VT = 0 + j9.7993
  • #34
Impedances are complex values and you use the entire value, both real and complex parts, when determining voltages, currents, or net impedance. The time to worry about real and imaginary parts separately is when you're dealing with power dissipation.
Likes gracy
  • #35
Right I see,
sorry for posting, I was just checking that I did it correct as I also have the same question as him... ill just make my own thread
