Electrical Engineering, power system, transmission line
The discussion revolves around a homework problem related to power transmission in electrical engineering, specifically focusing on a 400 kV transmission line with a given length and reactance. Participants explore how to calculate the power that can be transmitted while considering the power angle and the implications for static stability.
  • Homework-related
  • One participant notes the formula for power transmission but expresses uncertainty about how to proceed without knowing the receiving end voltage (Vend).
  • Another participant suggests that both sending and receiving voltages can be assumed equal in magnitude, which is often the case in practice due to VAR compensation.
  • Some participants emphasize the importance of knowing the current and the load connected to the receiving end to determine the voltage drop across the line.
  • There is a contention regarding the voltage drop, with one participant asserting that the absence of resistive elements means the voltage drop will always be zero, while others argue that the inductive reactance will cause a voltage drop that cannot be ignored.
  • Participants discuss the need for series compensation in the line and the implications of assuming a flat voltage profile.
  • Clarifications are made regarding the distinction between absolute and instantaneous voltage magnitudes, with some participants advocating for the consideration of rms voltage drop.
Participants do not reach a consensus on how to approach the problem, with multiple competing views regarding the assumptions that can be made about the voltages and the necessity of knowing additional parameters such as load characteristics.
There are unresolved assumptions regarding the load connected to the receiving end and the implications of reactance on voltage drop calculations. The discussion reflects varying interpretations of the problem's requirements and the necessary conditions for solving it.
louisnach
A 400 kV transmission line has a length of 500 km and a reactance of 0,4 Ω/km. How much power can you transmit, if the power angle (the angle between the voltages of the beginning and the end) is limited to 25 degrees? What would then be the line’s boundary power limit for static stability ?
Hi, in the lecture we have a formula that give P =(Vs*Vend)*sin(power angle)/Z
where Z is the impedance of the line so i guess it is 500*0.4 reactance, Vs i=400kV (source voltage) but in the problem i don't have Vend voltage at the end of the line, how can i solve the probleme without knowing that ?
Vs and Vend are the magnitude of voltage. So what is the voltage drop across the line?
Hint, look at the given impedance of the line. V=IZ
This problem can't be solved without knowing the sending end voltage. The given 400kV is the receiving end voltage.
However, I believe OP can assume both the voltages to be equal in magnitude (which is mostly the case in practice, thanks to VAR compensation).
The end voltage CAN be solved for with the given material.
Here is a hint.
Given the impedance of the transmission line, what is the voltage drop across the line (in magnitude).
another hint, you don't need to assume
How can we determine it without knowing the current? There is no information about the load that is connected to the receiving end.
the magnitude of the voltage loss will not change because there is no resistive element. therefore the voltage drop will always be zero
No.
What about the I*XL drop across inductive reactance of the line? This is why you need series compensation in the line.
Absence of resistance means no power loss in the line. But that doesn't mean both the voltages are equal in magnitude. Without knowing anything about the load (pf and MVA) or the sending end voltage, this problem can't be solved. Or OP can simply assume a flat voltage profile (as a result of compensation, which is not mentioned).
cnh1995 said:
No.
Im talking about the absolute magnitude, not instantaneous magnitude, which are the voltages listed in the equation. I should have clarified.
Thanks for your replies of both of you, i think indeed we have to consider same magnitude so by using the formula it is just (Vs*Vs)/(500*0.4)*sin(25 degrees),
  • · Replies 18 ·
  • · Replies 28 ·
14K
